Home > Puma (Tdci) > 2.4 white smoke on start up
Page 2 of 2 <12
Willfindlay
England 2009 Defender 90 Puma 2.4 PU Arles Blue
When you say the vcv will sort itself out over time if you don’t do a relearn, what does this mean?
Post #898429 15th Apr 2021 1:31pm
It self learns, to peak performance characteristics over so many miles.
I simply fitted mine, simple as that and job done and she runs better and has ever since with better performance too.
No issues at all, and so have many many others done exactly the same.
I was hesitant myself at first, but it’s not a problem at all. I did mine a year and a half ago and about 20k I’ve done since then.
If you prefer you can always get it fitted for you and have the relearn done, if this is LR I doubt they’ll fit anything but LR Genuine parts a significantly more expensive part plus labour fees etc.
I did mine myself with the PFJones VCV, for about £40. No programming, no issues. Performance is great.
I have been out the last few days and thought how well she pulls, especially in higher gears.
And the idle is smoother. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #898542 15th Apr 2021 10:52pm
bear100
Fitted mine on the drive, a bit tricky with big hands but not so bad, no issues at all with it relearning itself and much smoother from the start so can only get better 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #898625 16th Apr 2021 1:21pm
jst
I have done 4 of them. 1 i did the relearn the others did it over time. I have also had one duff VCV, in that once fitted vehicle wouldnt start. refitted old one and it started again.
the white smoke could just be glowplugs not 100% and its cold. i have 3 2010 defenders they all smoke on cold starts with cold ambient. (but dont have the irratic idle!) Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #898657 16th Apr 2021 6:17pm
Page 2 of 2 <12
