Home > Puma (Tdci) > 2.4 white smoke on start up
Willfindlay
England 2009 Defender 90 Puma 2.4 PU Arles Blue
My 2009 2.4 has had quite a lot of white smoke on startup, but as soon as you set off it disappears and there is no smoke once the engine is warmed up. The engine never runs hot, and the coolant levels are all correct. I was wondering if anyone knows the reason for the smoke on startup. Thanks
Post #898292 14th Apr 2021 8:58pm
Is the idle stable when cold? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #898298 14th Apr 2021 9:13pm
Willfindlay
No, it’s not great but as soon as you increase the revs then let it idle again it’s fine.
Post #898300 14th Apr 2021 9:17pm
Okay, do you find she pulls strongly in 6th or feels sluggish?
Also does the idle run smooth once up to temp after a run?
If it does, the it might be a good idea to change the VCV.
Also you may wish to run Millers Diesel additive too, I run this constantly and will help keep injectors cleaner and various other items.
Also having the MAF and MAP sensors with a proper spray cleaner may help too.
Issues when cold on first start are commonly akin to VCV issues, I recently changed mine and was well worth doing.
PFJones supply these.
You need no special tools and doesn’t need programming in either.
If yours is original as was mine, then it probably is due for a change.
This is a suggestion, and not guaranteed to be the culprit but may well solve the issue without spending too much money.
I would definitely recommend the additive first as this will give everything a clean through anyway including the VCV.
And is safe to use permanently and will run smoother, with a little more MPG and power.
Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #898307 14th Apr 2021 9:30pm
jst
^^^ VCV i would also suggest. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #898308 14th Apr 2021 9:36pm
Willfindlay
Yes, it pulls really well in all gears, and yes once upto temperature the idle is smooth. I’ll get some millers additive and try that and look into changing the vcv. Thanks for your help.
Post #898310 14th Apr 2021 9:39pm
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #898313 14th Apr 2021 9:53pm
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
I’d suggest one or more leaky injectors. Leak a little once engine not running as the fuel rail stays partly pressurised. When you start the engine it burns off the wet diesel in the cylinder. Often will feel like it’s misfiring just until the fuel is burnt off. 2011 130 Utility Body
2005 110 Van
Post #898317 14th Apr 2021 10:23pm
bear100
How are leaky injectors fixed? DIY job? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #898323 14th Apr 2021 10:51pm
Willfindlay
Custom 90 Steve
I’ve been looking at several vcm’s, and it says a pump learn procedure needs to be carried out with a diagnostics tool?
Post #898347 15th Apr 2021 7:44am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Youll probably find it’s worse on very cold days, but before you go spending lots of money try a diesel system additive.
Make sure you have no more than a quarter tank when you add it and get the engine nice and hot with a good half hour drive to flush things through.
This is also a good thing to do before taking your vehicle for MOT every year, a bit of a flush out may help on emissions testing. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #898350 15th Apr 2021 7:51am
jst
officially you need to do a learn after fitting a vcv, its better if you do do the learn but it will work fine without and sort itself out. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #898360 15th Apr 2021 8:47am
jst
you can do a VCV relearn with a BAS tool i believe. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #898361 15th Apr 2021 8:48am
If you haven't already done so, you might want to take a look at this thread:
https://www.defender2.net/forum/topic49151.html
Post #898373 15th Apr 2021 9:23am
Willfindlay
Thanks I’ll have a look.
I’ve ordered a vcv valve and some millers diesel additive so I’ll let you know if there’s any improvement.
Post #898394 15th Apr 2021 10:45am
