Home > Maintenance & Modifications > Bulkhead replacement
billewizz
Guys I’ve just purchased a 200 tdi 90 reject that the previous owner has started to rebuild on a galv chassis, but has purchased a later what looks like a tdci bulkhead with no air flaps, I know this has been done to death for those fitting the tdci dash but I am wanting to fit all the original 200 furniture which came with the truck as per standard 1992 defender.
I am unsure if I am going to run into trouble retaining this bulkhead does anyone know if this is the case.
Post #897850 12th Apr 2021 11:07pm
donmacn
As you say, it's a topic that's been done. I'd suggest a search to pick up more details.
I asked this same question on here, maybe 9 months to a year ago as I was helping a friend prep for a 300Tdi 90 bulkhead swap. As I say, I can't remember the details but the gist of it was that there were too many differences to make it straightforward job.
When I did my own one (a 94 Tdi) it was a Td5 bulkhead that was used - it's a lot closer to the original.
You might find it's reasonably cost-effective to sell on the Tdci bulkhead and get another one closer to your vehicle? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #897916 13th Apr 2021 9:50am
billewizz
Thanks Donald I was thinking along those lines
Post #898042 13th Apr 2021 6:32pm
trailbear
Are you sure it isn’t just the correct bulkhead for the vehicle but with the “ flap blanks “
Specified by the owner that you bought the vehicle from.
If you have a look at some of the bulkhead manufacturers, Shielder is one I think, they offer the option
Of specifying a bulkhead with blanks for about £150 extra.
If you look at the Arkonik website, they appear to build most of their rebuild vehicles with “Blanks “ instead of the
Flap design, stops all the leaks ( well some of them ) I guess.
I had thought about doing this with one of my vehicles I am thinking of rebuilding.
Post #898137 14th Apr 2021 9:51am
billewizz
Ahh I had no idea this was an option, but I believe it is a used one the previous owner has started to paint but now you have sprinkled on the seeds of doubt and it may be a better option to retain it and assist with the leaks, it puts Evan more emphasis on understanding if it can be retained and all the dash swapped from the original.
Post #898239 14th Apr 2021 6:20pm
trailbear
Ah right, I wasn’t aware that it had been a used one, Perhaps someone better versed in
The bulkhead area might be able tell you how to check.
Apologies if I have caused any confusion 😳
Post #898242 14th Apr 2021 6:28pm
donmacn
I had a little look, and found the thread I was after: https://www.defender2.net/forum/topic60808...i+bulkhead
Unfortunately, while it's got a strong 'conclusion' it's pretty short on precisely why it's hard work to fit a newer bulkhead to a Tdi vehicle.
I imagine it's going to be all sorts of issues like having the wrong mountings for heater box, dash, loom, pedals (esp accelerator), wiper and motor....
I'm not aware that I've seen one (A TDCi bulkhead...) up close and personal, in the nude! If you could post a pic I'm sure I could point to some basic questions. Donald
in the past..
Post #898249 14th Apr 2021 6:48pm
billewizz
Thanks guys no problems trailbear all gets the juices going, collection planned for Sunday so I can have the old and new together for comparison
Post #898316 14th Apr 2021 10:18pm
