Home > Td5 > Rear side window seal replacement bonded windows.
G-P
United Kingdom 2006 Defender 90 Td5 CSW Zermatt Silver
Hi All,
Can anyone tell me how I can replace the rear window seals to stop them rattling on my 06 90 CSW?
All I can find is info for the non-bonded ones.
Thanks
Post #897581 11th Apr 2021 10:11pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
https://www.mudstuff.co.uk/collections/gar...window-kit 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #897608 12th Apr 2021 3:12am
excossack
I can 2nd the GO seal kit, worked a treat on my sliding windows. I replaced them about 4 or 5 years ago and still rattle free. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #897625 12th Apr 2021 8:13am
G-P
Hi,
Thanks for the link, unfortunately you need to remove the rear windows to fit this kit, however mine are bonded rather than riveted in and I can’t find a kit for these.
Is there a way of doing this without removing the windows?
Post #897643 12th Apr 2021 8:52am
excossack
From memory doing my windows (riveted in) I had to remove the windows to get to the screws that hold the frames together so I could get the glass out. 1999 Defender TD5 110
Regards
John M0VAZ
Post #897653 12th Apr 2021 9:28am
Dinnu
Quote from mud site:
Will it fit my vehicle?
Fits Land Rover Defender factory fitted rear sliding windows with 4mm glass that contain felt linings. Fits Model Years 1984 through 2001 with the single sliding glass panel.
NOTE: On post 2001 Defender side windows, the window frames are bonded into the body side panels. This makes removal of the window frame very difficult. This kit will therefore only work with the earlier style window frames that are riveted in place.
To my knowledge, the bonded type was introduced with the puma engine, from 2007. My 2012 still have the felt lining, which rattle like crazy. If I understand correctly, the frame has to be removed from vehicle and split to install the Garisson seal, hence the problem to install on Puma style frames.
So that means the only alternative for the puma sliding windows is again to install RTC6462 ? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #897657 12th Apr 2021 9:42am
G-P
Mine has the bonded style unfortunately, from what I can work out late TD5 have these.
Sounds like I need to get a car window company to remove and re-fit! Suddenly a cheap fix becomes an expensive one!
Post #897772 12th Apr 2021 7:18pm
