![]() | Home > Technical > Genuine spot lamp loom |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5355 ![]() ![]() |
I have been recently installing the main loom, but i have came a cross and problem,
maybe you lads can help me, as its stopped me from going any further with installation ![]() the instructions say this ![]() Click image to enlarge ![]() Click image to enlarge but no blue and orange to splice into on the dash harness? Either something is missing or my dash loom is from a earlier model or something, but this has put the brakes on. ![]() Click image to enlarge Any help there lads? The instructions are pretty hit and miss here. My dad looked at it, and he just backed away, after he saw the instructions. He said that's pretty sodding poor that, no pin or wire colour to go into. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Blue and white wire in cavity 1.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thanks fellas, is there a fault with the instructions or am i just miss reading here? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
No post 07 blue / orange wire at ins cluster is main beam pin 27 on plug
pre 07 blue / white wire at ins cluster is main beam pin 1 on plug |
no blue/ wire on the harness on this model,
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Green /white wire pin 2----------------------- red / slat gray wire pin 11
![]() Click image to enlarge Last edited by dorsetsmith on 7th Apr 2021 4:20pm. Edited 1 time in total |
thanks fella, i will have another go at it on friday, as i do have a to change the dash over for replacement,
when you mean Green /white wire pin 2----------------------- red / slat gray wire pin 11 do you mean try both wires? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
use plug pin out above and work out wire colour for pin 1 plug
