![]() | Home > General & Technical (L663) > Access, Normal and Off Road heights |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
looks about right - drops around 45 mm
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 ![]() ![]() |
took a picture of our New Defender and a friends in access height next to our RRS (L320) the Sport was in
normal ride height, they looked to be about the same level although each was in a different setting. That may give the illusion of the Defender not reducing its height compared to the other LR air suspension models. ![]() Click image to enlarge yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 ![]() ![]() |
Have you measured the height differences and compared with specs? Access is speced -40mm compared to Normal. |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2028 ![]() ![]() |
Not yet but that’s my next thing to do. 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Q86ARR Member Since: 28 Feb 2017 Location: Earth Posts: 42 ![]() |
Ride height:
Normal - 90 vehicles 218 mm (8.58 in) Normal - 110 vehicles 218 mm (8.58 in) Off road 1 40 mm (1.57 in) above normal Off road 2 75 mm (2.95 in) above normal Access (maximum) 40 mm (1.57 in) below normal High speed 13 mm (0.5 in) below normal |
Well, I measured mine just now (a 110) and the heights were as follows from the ground to the wheel arch lip
Access - 850mm Normal 890mm Off Road 940mm 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
You need to measure from the centre of the wheel to the edge of the wheel arch
