![]() | Home > Faults & Fixes (L663) > Foam insert bottom of screen... |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1141 ![]() ![]() |
Anyone else got the foam strip at the front of the dash/bottom of screen joint fitted wonky? Mine is not fitted straight. Not a big deal but slightly annoying.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
SN Member Since: 30 Jun 2007 Location: SK6 Posts: 729 ![]() |
Will it move or does it appear glued in? can you use a needle or similar stabbed in it to help manouvre and rectify it?
One for powerfuluk to do a video on methinks ![]() ![]() ![]() ![]() |
It’s stuck to the back edge of the dashboard. I tried to push it down, but glue seems quite strong. It’s really not worth hassling over to be honest.
If it means the dash has to come out to fix, I’ll live with it. I’d rather not have a new car with all the associated broken clips and potential rattles a dash removal might cause. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3521 ![]() ![]() |
This is been a thing on many LR models, my Fl2 had wonky foam. 24MY 90 D250 HSE, Tasman Blue
My 90 is the same, wonky foam along the base of the windscreen. 24MY 90 D250 HSE, Tasman Blue
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
I can see about 2mm of the foam on my “old” (ie very early production) New Defender but it is very evenly applied, straight and it looks like it it something to stop the dash tapping on the glass.
![]() Click image to enlarge Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
