Home > Td5 > 2003 Td5 90
mustafasoleiman
United Kingdom 2003 Defender 90 Td5 XS CSW Indus Silver
2003 Td5 90
Good day, I have a 2003 Td5 90 and my wife drives it everyday for work... She is complaining that it is very tiring because of the noise etc... Still she loves it and it is right for her work.
To avoid having to get something else to replace the Defender what do you suggest can be done to make the car less noisy and tiresome?
Many thanks for your help in keeping wife and car happy together! (at least i get to drive it the weekends...
Alex http://instagram.com/h4vou/
Post #895763 3rd Apr 2021 4:05pm
Alex, if you have a search for sound proofing you'll find dozens of threads with lots of useful stuff in them. The basic premise though is to add some mass to various panels (Silentcoat or similar) to stop vibration and then cover everything you can in self adhesive foam to absorb airborne noise. Here's a couple of posts in my own build threads to get you started:
https://www.defender2.net/forum/post622546.html#622546
https://www.defender2.net/forum/post637884.html#637884
https://www.defender2.net/forum/post711655.html#711655 Darren
Post #895767 3rd Apr 2021 4:50pm
roel
http://www.bose.nl/nl_nl/products/headphon...lsrc=aw.ds
Laughing Roel
2003 90 Td5 (2009-now)
Post #895770 3rd Apr 2021 5:17pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Is the clutch heavy, there’s a few different options available 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #895771 3rd Apr 2021 5:39pm
bluebottle
If gear changes are an issue plenty of people swear by slickshifts too.
A more expensive option, but worth it if not needing to tow etc., is to look at changing the gearing of the transfer box. I have done this and it effectively means the engine does fewer revolutions for the given speed = quieter engine noise.
Post #895800 3rd Apr 2021 10:25pm
landy andy
I found a remap makes driving a lot less tiring. Saves on changing gear so often and quietens engine at speed.
Post #895801 3rd Apr 2021 10:27pm
Beero
I have a 2005 td5 90 van back and found a lot of noise was coming from the weight of the spare wheel rattling the back door. I removed it and strapped it to the back of the bulkhead temporarily and it quietened things a lot. I also put padding around things like the jack and wheel chock to stop them rattling. I don't carry heavy loads so lowered all the tyre pressures to 25 psi. I also put heavy duty rubber mat on the loadspace floor. I now don't feel the need to do the soundproofing that I was considering doing before.
Post #895803 3rd Apr 2021 10:56pm
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
What tyres is on? A lot of noise can come from rough terrain tyres!
Regards
Christian 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #895842 4th Apr 2021 10:09am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
A few things to consider...
1- sound insulation of the roof is a must, remove headliner and add butyl then foam on top of that. Replace headliner
2- doors, remove door card and add butyl pads to the door skin, place door card
3- add sound deadener matts to the seatbox. Like the wright off road mat system
4- add sound insulation to the underside of bonnet and around the edge add a rubber seal (a lot of noise comes from there)
5- add a slick shift kit to the shifter, a lot less flinging your arm about when shifting makes it more car like
6- bit pricey to add but an overdrive unit (Global Roamerdrive) reduces RPMs and internal cab noise/vibration considerably
7- replace clutch spring, clutch slave or master with LOF kits. They DRAMATICALLY reduce clutch effort
8- add Disco II upper shock tower cone ring isolators to the front springs and regular rubber spring isolators to thr top of thr rear springs.
All of these I have done to my 110 CSW as my daily driver and these mods render your Defender much more pleasurable to drive and dramatically reduces driver fatigue. Check out links below, I have not used all of these products but similar ones. The links are just for you to get an idea of what is possible.
Good luck (hope you keep the Defender) Thumbs Up
Butyl sound deadener (used throughout my 110j
https://www.b-quiet.com/
Rubber sound mat system (not used but similar JLR OEM one used in my 110)
http://www.wrightoffroad.com/
Slick shift (installed in my 110, one or the best mods I have done)
https://www.onlinegearboxparts.com/product/series-slickshift/
Lighter clutch pedal. (Installed in ky 110)
https://lofclutches.com/store/clutches/pedal-assist-products/
Overdrive to reduce RPM, vibration and noise (installed in my 110)
http://roamerdrive.com/
Front upper spring isolator (installed in my 110)
https://www.amazon.com/RBC10011-Suspension...B06XTYRVB3
Rear upper spring islolator (different lnes installed in my 110 as the springs are larger diameter)
https://www.roverparts.com/suspension/springs-hardware/anr2938/
Bonnet sound insulation (not used but installed B-Quiet products underside of bonnett)
https://www.nkgroup.co.uk/product/full-lan...ofing-kit/
Bonnet edge self adhesive rubber seal (installed similar product)
https://www.ebay.co.uk/itm/Car-Pillar-Door...SwQJlf2HBG 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #895883 4th Apr 2021 3:14pm
+1... and add an ex disco 1.2:! t/box.... so the engine is revving less per given speed.
Post #895901 4th Apr 2021 6:09pm
mustafasoleiman
Wow! Thanks all for the many useful suggestions!
Once Easter is over and family engagements are over I’ll go thru them.
One thing I forgot to mention is that I will need someone else to do this work as I have no space (we live in london), nor the ability to do all this... any garage or company that can do some of this work near london? Expensive I’m sure but still cheaper than the alternative (and I get to keep my love... the car (and the wife too!))
Again thank you.
Post #895941 4th Apr 2021 11:18pm
mustafasoleiman
Again thank you.
Post #895943 4th Apr 2021 11:18pm
Retroanaconda
How do you manage to have a Td5 in London, is it somehow exempt from LEZ?
Post #895963 5th Apr 2021 8:59am
Procta
mine was remapped and had an ashcroft transfer box fitted to make it quieter, also a stack load of sound proofing. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #896105 6th Apr 2021 1:30am
mustafasoleiman
somehow it is...
Post #896172 6th Apr 2021 12:11pm
