Home > 130 > Chassis bracket measurements request
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
I'm looking for the dimensions of the brackets shown in these photos of AndrewS's longshanks build if anyone has a rule and a spare five minutes please?
My chassis was supplied with the wrong brackets, the supplier has kindly offered to make some new ones but they need dimensions to work from. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #894454 28th Mar 2021 10:56am
Oldrover24
United Kingdom 1997 Defender 90 300 Tdi HT Coniston Green
The drawing is one that sits on the body cross member, small gusset piece not shown but easy to guess the size. for the rear mounting rail I used a piece of 40mm box section and added mounts at the ends so I now have tie downs in the tub. Think I have a sketch for the centre bracket somewhere, same as ones across the rear.
Post #896100 5th Apr 2021 11:48pm
Oldrover24
Post #896101 5th Apr 2021 11:51pm
Shroppy
Oldrover, that is immensely helpful thank you! I like your solution for the rear mountings too. If you do have a sketch for the middle bracket it would be very much appreciated. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #896165 6th Apr 2021 11:49am
Oldrover24
Hi Shroppy, this is a rough sketch for the other style bracket, hope it helps, side flanges not on drawing but again easy to work out.
Post #896398 7th Apr 2021 9:36am
Shroppy
Superb! Many thanks. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #896399 7th Apr 2021 9:42am
