![]() | Home > Modifications & Maintenance (L663) > Rear seat base removal on a 90 |
Tom_T Member Since: 08 Nov 2020 Location: Essex Posts: 87 ![]() ![]() |
It will be the first thing I’m going to investigate how to do once mine arrives in a few weeks.
Scrumps Member Since: 24 Feb 2021 Location: Somerset Posts: 108 ![]() ![]() ![]() |
Hi,
I’ve just tried our 90 HSE and get close to the above photo quite easily. I can get the back down, level with the top of the rear speaker, with the addition of a bit of weight / a load. I think it will get easier if/when the back seats have had a bit of use as it’s the seat back to squab arrangement that stops it going down more easily. I can’t seem to achieve any sort of “lock” in the lowered position. Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 ![]() ![]() |
Shame they didn’t make them fully removable a la Yeti and quite a few other types. I doubt there’d be that many peeps that intend to regularly put humanoids in the back of a 90, would be really good boot space with car configured as a 2 seater. Then bung the seats back in if required, they’ve missed a trick there.
Hi,
I think, if you look closely, the rear seats of a 90 sit over the rear axle/diff/running gear. That appears to be why they don’t fold forward at the base and the alloy strip is there to stop small items/shopping rolling under the seat and being inaccessible. Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
Someone posted that they removed the rear lower seat swabs - that brought it almost level.
Can not find that post. |
Apapy Member Since: 08 Jan 2016 Location: Brussels Posts: 42 ![]() ![]() ![]() |
Well, if somebody could find that post (on a 90, not a 110), I would be very glad
Saw it on FB yesterday also - can not find that now either
Nitroneil Member Since: 05 Mar 2019 Location: Stirling Posts: 132 ![]() ![]() |
This one?
https://www.facebook.com/groups/6862732818...239984263/ 90S D250 fuji and loving it. |
No - not that one - I will have a look again this morning.
https://landroverforums.com/forum/2020-def...462/page2/
Same info - different forum - removed seat base (Post 12) |
![]() ![]() ![]() ![]() Thanks |
So I checked and indeed you can remove easily the rear seat base.
Just a few clips, vertical traction and this it it. Attention - some clips might get loose and there are deep and narrow holes where they can easily hide ![]() ![]() Now seats fold flat or almost ... Ps. Still don’t understand why the system of the 110 has not been used here |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
I’m speculating here but what is underneath the rear seats of the 90 (in the way of rear transmission) that because of the longer wheelbase of the 110 means that item is under the boot floor of the longer model and not under the seat base? Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 457 ![]() ![]() |
After retrofit to commercial, a picture from all the hardware that came out under the rear seat/bench from the 90
![]() Click image to enlarge No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
