Home > Maintenance & Modifications > Swivel area leak, help/advice appreciated.
Pat
Wales
For the more knowledgeable ...
Noticed splatters on my front mud flap and found fluid leaking from the swivel area. Any suggestions to what might be going on down there would be much appreciated. Have a few journeys coming up, should I be re thinking?
Thanks. It started with a kiss, never thought it would come to this.
SIII CSW Safari, limestone, (JAC 914N). Where is she now?
It's not a car, it's a way of life!
Post #895765 3rd Apr 2021 4:44pm
williamthedog
The amount of oil leaking there you can safely say that the swivel seals are shot. Not a hard job, just time consuming and a bit messy. Or you can cheat and cut the seal and fit. Plenty of info on this, do a search and decide which way to do it. Thumbs Up
Post #895775 3rd Apr 2021 6:41pm
landy andy
If you put the steering on full lock both ways a check the swivel balls and they are all smooth, no rough part, rust, and no groves then just fit new seals and relubricate swivels. If the swivel balls are damaged then they or it will need to be swapped.
Did mine earlier today.
Post #895799 3rd Apr 2021 10:25pm
Pat
Wales
Thanks guys, pretty much as I was thinking, but always worth asking on here.
Thanks again. It started with a kiss, never thought it would come to this.
Post #896316 6th Apr 2021 9:06pm
