Home > 130 > 130 Side Steps
J_Defender
United Kingdom 2006 Defender 130 Td5 HCPU Java Black
130 Side Steps
Does anybody happen to have a pair of these side steps fitted to their 130 (or 110)? I'm keen to see how they look before committing...
They're the Bearmach 8904's.
Thanks in advance...
Post #895083 31st Mar 2021 12:58pm
Smyles_
Denmark 2008 Defender 130 Puma 2.4 HCPU Cairns Blue
Can't say I've ever seen those in particular fitted but judging by the short mounting bracketry I'd hazard a guess that they'd probably sit just below the sills like here:
 Stuart
Cummins 130 Build Thread
Instagram
04 110 Double Cab - Black (gone)
58 130 Double Cab HCPU - Cairns Blue
Post #895085 31st Mar 2021 1:08pm
J_Defender
Thanks for the reply, Stuart, I'd agree that they look to be mounted a little higher as per the image you posted.
Could do with comparing them side by side with other options to get a proper idea, really.
Post #895446 1st Apr 2021 8:37pm
Smyles_
I'd rather just have rock sliders with protruding steps that replace the sills rather than that setup. just looks cumbersome to me.
OR
 Stuart
Instagram
Post #895602 2nd Apr 2021 6:11pm
Smyles_
I may actually have just found a 130 with those steps installed here
They seems to have removed the sills entirely, maybe so you can get your foot under?
It doesn't however support my initial theory with the short bracketry... maybe the product photos are at an angle that they look short or, they extend them with that truck having a lift?? Stuart
Instagram
Post #895606 2nd Apr 2021 6:18pm
J_Defender
That's really helpful, thank you very much!
Post #895712 3rd Apr 2021 10:11am
J_Defender
Not keen on the bare-sill look personally. I would also tend to agree with you, looks like they have extended the brackets in this image ^
Post #895715 3rd Apr 2021 10:12am
J_Defender
I just think it looks a little "unfinished" in this side profile image:
Post #895717 3rd Apr 2021 10:14am
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
Smyles_ wrote:
I quite like these. Anyone knows if they're off the shelf of custom made, and where they can be purchased? Defender 130 HCPU Td5 MY2000
Post #897902 13th Apr 2021 9:09am
J_Defender
To be fair, they look like standard rock sliders with chequer plate inserts, but I could be wrong...
Post #897914 13th Apr 2021 9:43am
camelman
Shire fabrications do 60mm rock/tree sliders to fit 130 for reasonable money. I have them on the 110 and getting some made up for the 130. Mine need to be 6 inches longer than standard 130 sills however.
Post #897927 13th Apr 2021 10:21am
Smyles_
They were custom made as far as I'm aware. Can't imagine it be that hard for you or a shop to replicate - just a angled cut to the end of the tube. Thumbs Up Stuart
Instagram
Post #897970 13th Apr 2021 1:26pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Would be interested to see the 130 sliders camleman, can't see them on their website? 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #897972 13th Apr 2021 1:43pm
J_Defender
I'm guessing it'll be these in 130 flavour:
https://www.shirefabrications.com/rock-and...60mm-tube-
Post #897985 13th Apr 2021 2:18pm
RoadForce
I understand what would make you say that, but I think you're wrong: with standard rock sliders the tube isn't offset / angled downwards but parallel to the "sill"-part.
True, but I think it would be more convenient and probably cheaper if I could just purchase a set, hence the question. Defender 130 HCPU Td5 MY2000
Post #898185 14th Apr 2021 1:46pm
