Home > Td5 > Door cards repair tips
ibexman
Yes that old chestnut. .I have a broken off snap sac clip which needs re gluing I’ve tried super glue it just comes off ,does anyone have any tips on a successful repair ,I’m thinking maybe a 2 part resin glue. Thanks Chris
Post #894902 30th Mar 2021 12:15pm
I've had some success in the past with that type of glue - Araldite or similar. Darren
Post #894910 30th Mar 2021 12:46pm
If it in a thick enough area of the card, you can fit a short countersunk woodscrew with a head of an appropriate size to fit the nylon pin.
Post #894913 30th Mar 2021 12:50pm
ibexman
It’s minimal in that area what is it made of it says pvc on the card but on cleaning the hole it’s very fibrous 🤔
Post #894916 30th Mar 2021 12:54pm
dorsetsmith
Door Card Fir Tree Fastener Receiver (The Part That Breaks in the Door Card)Suitable for EZM500050 needs to be Bonded in
Product code: EZM500050REC
BEARMACH are the stockers
Post #894921 30th Mar 2021 1:12pm
ibexman
Thanks for that it doesn’t say what type of glue to bond it in with 🤔
Post #894928 30th Mar 2021 1:43pm
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
Re: Door cards repair tips
Just did this repair a couple of months ago with Gorilla Glue two pack stuff. Failed the first time but the second time I left it clamped for ages and worked a treat. Still solid even after a test removal of door card.
Post #894933 30th Mar 2021 2:04pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Loctite/Hardman Double Bubble Epoxy works wonders and can be purchased in measured single use sachets that are pre measured Thumbs Up
e-bay search “double bubble epoxy” Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #894941 30th Mar 2021 3:28pm
Dinnu
I personally never had good success using epoxies (Areldite is an epoxy as well) on plastics.
I think polyurethane glues are better for this application.
I use Wurth bond and seal a lot, and I bet that it is very strong in this application.
I would still roughen a bit, especially the plastic thingy, and a good wipe with thinner (not white spirit). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #894962 30th Mar 2021 5:28pm
