Home > Modifications & Maintenance (L663) > Has anyone fitted roof rails after?
RRUK
The one thing I’d specced that mine isn’t coming with is roof rails.
I see they can be purchased but has anyone fitted them successfully? 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #891696 15th Mar 2021 10:46pm
SN
simon at powerfuluk has - note you're going to need a 5 point-star-with-centre-pin driver head to get the original trim off - simon does call them out.
footnote: I shall be checking how neatly my dealership has done mine when it turns up Whistle
To be fair doesn't look any harder than the roof rails I put on my first Disco 3 about 15 years ago - I actually found the trims I took off in the garage roof space at the weekend! Rolling Eyes Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #891709 15th Mar 2021 11:17pm
Tim in Scotland
I had them fitted 2 months after taking delivery of the car but got the dealer to do it while the car was in for warranty work, I had the rear recovery eyes fitted at the same time. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #891744 16th Mar 2021 9:35am
RRUK
Thanks for the link.
Already have the Torx Plus bits so I'm sorted on that front. 2016 D4 HSE
Post #891747 16th Mar 2021 9:38am
GSKM
WRT the 5 point-star-with-centre-pin driver head fitting, some idiot cut the cable of my hedge cutter whilst I... er they were using it. I took all but one torx bit out with a normal torx driver. The last one was a safety torx bit, with the centre pin. I did not have the tool to remove it. However an electrical screwdriver rammed between the points and the pin worked well to remove it. I wouldn’t advise using that method to remove roof bolts though. Hmm, the thought of the screwdriver slipping on the roof doesn’t bear thinking about. 1983 110 2286 petrol hardtop.
2015my Freelander
2018my Discovery Sport.
Post #893951 25th Mar 2021 8:47pm
