Home > In Car Electronics > Tow bar electrics |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3465 |
Get the adapter plug from 7 to 13. Quick fix 1951 80" S1 2.0
23rd Mar 2021 1:57pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 956 |
You’ll need something like this...
Click image to enlarge Or this Click image to enlarge They do reverse ones also depending on your set up Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT Last edited by Leamreject on 23rd Mar 2021 2:27pm. Edited 1 time in total |
23rd Mar 2021 2:22pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
That top adaptor is the wrong way around (for 13pin vehicle to 7pin trailer).
Do you have both 12N & 12S (black and grey 7pin) sockets on the defender currently? If you only have the black 12N one then I would just straight swap it for a 13pin socket. The 13 pin system is so much better than the old 7pin ones. If you have both sockets on the defender it can be slightly more messy to wire both cables into a 13pin socket - still better in my opinion though. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
23rd Mar 2021 2:26pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16895 |
It shouldn't have a bearing on your solution, but you might want to bear in mind that if you replace the 7-pin socket currently on your Defender with a 13-pin socket, the new socket will be tested as part of the MoT test. Quite wjhat aspects of it are tested, I don't know, but 13-pin sockets are in-scope, 7-pin sockets are not.
23rd Mar 2021 2:43pm |
Good point Blackwolf, MOT test should only cover:
So only the functions of the standard 7pin 12N socket. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
23rd Mar 2021 3:03pm |
chris d3 Member Since: 06 Apr 2010 Location: sunderland Posts: 368 |
I’ve got the adapter but will it power the battery charger in the trailer
23rd Mar 2021 11:30pm |
If you've only got a single black seven pin 12N socket then no, as the live for that function comes from the grey 12S socket.
If you've got two seven pin sockets and an adapter to convert to 13 pin then yes it will. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
24th Mar 2021 7:19am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
The 13 pin electrics on my 90 have never been tested (I always watch the MOT because I'm sad like that )
13 pin in my opinion is a far, far superior connector than the 7 N+S setup in every way - more reliable too 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
25th Mar 2021 7:48pm |
Where’s the best place to get the 13 pin?
Is it a straight swap on the defender |
26th Mar 2021 4:46pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 741 |
Brought mine from paddock spares and technically plugged it myself Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
26th Mar 2021 6:38pm |
cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308 |
Think it only became part of the MOT inspection from February 2021. Richard Either a 90, 110 or 130. Discovery 5 |
27th Mar 2021 5:38am |
Mine was MOTd in March so should have been tested. Would have passed anyway as it all works as it should 2002 90 Td5 Station Wagon
28th Mar 2021 9:26pm |
