Home > Technical > Replacement UJ sizes
LANDROVER
I know there is a few sizes but somehow I have confused myself silly between my Series...LR90 and Td5 Laughing
I'm a numpty and cut my UJ in half to remove it so no clue on its original size now Embarassed
I ordered a replacement TCV100010G and it appears slightly small....
I replaced the propshafts a few years ago with new ones and cannot remember where or finds paperwork.
Measuring the outside of the yoke is 94mm and inside is about 81mm between circlips....approx
The replacement joint is 75mm approx.
What size do I require?
I'm guessing 82 but I think it will be a squeeze...but I may be mistaken? Thumbs Up
Post #893719 24th Mar 2021 10:05pm
williamthedog
Why don't you give Gwyn Lewis 4x4 a call. I'm sure he'd be able to help you out Thumbs Up
Post #893765 25th Mar 2021 9:28am
landy andy
Or Bailey Morris who make props, and is where I buy my UJ’s from. They know everything about props in my experience.
https://baileymorris.co.uk/
Post #893766 25th Mar 2021 9:33am
dorsetsmith
STC4807
prop shaft UJ 93mm---------------- 1A---to----6A---i.e.2001--------------2006
93mm----wide---------------27mm----cup--dia
used on prop shaft tvb100610
RTC--3346----prop shaft---UJ---82mm----- wide----27mm---cup--dia
to chassis number CA--i.e-1986
TCV100010G----75mm---wide----27mm---cup--dia
All Propshafts from 2A638134, except TVB100610
FTC 4198 superseded by tcv100010
75mm wide
27mm cup diameter
From CA252579 to 1A612404, Front & Rear props
From 7A, Rear prop - 90 only
Except Front Propshaft from 7A
Post #893792 25th Mar 2021 10:50am
