![]() | Home > Wheels & Tyres > Smaller tyres to reduce height? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3644 ![]() ![]() ![]() |
According to https://tiresize.com/comparison/
235/85R16 tyres are officially 31.7" in diameter 235/75R16 tyres are officially 29.9" in diameter So that gives a 1.8" diameter difference, or a height difference of 0.9". But if your current 235/85 are worn, you may not see this much of a difference, as typically they can wear close to an inch in diameter before they get into the legal 1.4mm thread limit (assuming new thread height of about 12mm). Older Defenders used to come in 205R16 tyres which in my opinion looked badly proportioned. Another option is to get lowering springs (can add comfort), -1", personally think that makes a Defender look still good. Yes, it will loose 1" ground clearance. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
NH Member Since: 23 Mar 2021 Location: Redhill Posts: 2 ![]() ![]() ![]() |
Thanks for such a quick and thoughtful response - it's a good point about the existing worn tyres being smaller diameter than when they were new. Definitely food for thought.
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946 ![]() ![]() ![]() |
If you want to spend a lot of money you could look at air suspension.
Or you could fit the old school 90 tyres 205/80R16, but they look very small! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 887 ![]() ![]() ![]() |
Lower the floor by one inch? NOT such a throw-away, facetious comment, think about it...
Peter |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548 ![]() ![]() |
Is the garage for everyday use or only occasional like servicing, if the later let the tyre pressures down if you have compressor to blow them up again.
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
I had similar issues and fitted the -1” springs. QRZ M8VPF
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 408 ![]() ![]() |
I have a similar issue, albeit my 90 is lifted on 33’s and doesn’t fit in the garage at my new house
I’m fitting air suspension as it was the only way to get the usability I wanted without compromise. It’s low enough to fit in the garage, better on road handling especially with a trailer but I still get the lift and can keep the large tyres for when I go off-road |
I did not suggest air suspension as I was afraid of liability in case NH forgets to lower it before driving into the garage
![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751 ![]() ![]() ![]() |
Lower the garage floor would be my suggestion as above.
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2701 ![]() ![]() ![]() |
Have you thought about a few bags of pea shingle to throw in the back. Not too expensive, and yes i know will be a pain but if you have standard springs it might be enough to drop the height.
On my up and open garage door i moved the frame up as far as i could, cut the very top edge off the fibreglass door, shorten the inside door handle shaft, then added a strip along the bottom to stop the leaves blowing in. Mine is a 90, 2 inch lift and an external Safety Devices roll cage just to make things as fun as possible..... ![]() When we first moved here i had a 110, 2 inch lift on 33's. Before modding the garage door i bought at Sodbury a set of Discovery 1 205 wheels and tyres. Then changed them to use the garage. Again a pain, but both do-able and kept the truck out of sight. Good luck. |
