![]() | Home > Modifications & Maintenance (L663) > Thule roof bar question |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
Hi all
Trying to find some roof bars for the wife’s new 110 (2020) I have some Thule bars from the Disco 4 that appear to work on the same principal of slotting into the existing T-Bar system in the factory roof rails. However the brackets are a tad small. Does anyone have the part number for the correct Thule fitting kit ? They must be the type that fit the factory for roof rails ! Thank you Rich https://www.instagram.com/hustynminepark/ |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 ![]() ![]() |
Unbelievably difficult.
![]() ![]() Click image to enlarge ![]() Click image to enlarge |
Ha , thank you Sepp.
I’m not sure if it was because I was using my mobile but I really couldn’t find it ! https://www.instagram.com/hustynminepark/ |
Actually , just taken a look using the desktop computer !
Looked at the recommended foot fitting kit and it doesn’t appear to utilise the channels on the roof rails unless I’m being utterly stupid. I need some for Thursday so can’t risk the chance of buying something and having to send it back . 🙄 may just HAVE to go for the full front runner rack ! https://www.instagram.com/hustynminepark/ |
Where elso should it be fitted if not with the roof rails?
Have you read the intructions on the fit kit? (PDF link on the right side of Thule webpage) https://cdn1.static-tgdp.com/assetloader.a...&att=1 Trees! So many trees! ![]() ![]() ![]() (No offense, really just trying to help) ![]() |
Talking about roof racks.
My favorite would be the Eezi Awn K9 rack rather than the front runner rack, as it is using the OEM rails AND is 1800mm long (1560mm for Front Runner). |
dazadd Member Since: 28 Feb 2021 Location: Cranwell Posts: 12 ![]() ![]() |
Bluericky,
Just ordered some myself, you need 3040 Rapid System 'Fixpoint' Adaptor kit and 753 Rapid System Foot kit, not sure the part number for the rails as I'm re-using the ones from my Disco 5. D240 110 First Edition (1XD3, 4xD4s and a D5 now gone) Member of Disco Forums since 2006 |
Perfect thanks Dazadd !
Sepp, front runner has two options one that fits the rails. trees, trees ! https://www.instagram.com/hustynminepark/ |
That's exactly what I said, the Front Runner rack for the rails is 1560mm long (only).
No trees. No forest. |
Nitroneil Member Since: 05 Mar 2019 Location: Stirling Posts: 132 ![]() ![]() |
Doesn't seem such an easy answer for the 90 though, are they different? 90S D250 fuji and loving it. |
G4R1 Member Since: 17 Aug 2020 Location: Barnet/Limassol Posts: 131 ![]() ![]() |
There is another option on roof racks that seem quite interesting:
https://www.tbruk.com/pioneer-platform-defender110-8398-p.asp It’s 2128 X 1236MM And Foot Height is only 37mm ![]() Click image to enlarge 3.0L MHVE D200 S Pangea Green+Black Pack Adv. + Off-Road and Family Packs |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 443 ![]() ![]() |
Thule Wingbar 9595 and 3040 set,
See topic. I will proceed with this mod and share pictures. https://www.defender2.net/forum/topic76190...t=roof+bar No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
GreenMonster Member Since: 30 Sep 2020 Location: Virginia Posts: 77 ![]() ![]() |
The reason it’s hard to find is that Thule US and many other countries do not show a fitting for the new Defender. For some reason, South Africa and UK sites show the kit. I’ve posted this more than a few times so maybe search, but since you’re all here: 753 or 753100 feet, 3040 fit kit, 127 cm evo bars. Do yourself a favor and get the evo’s not the previous wing bars etc. You’ll thank me when you realize you can mount accessories in the evo t-slot without cutting the rubber thing every time. And yes, the 3040 fits right in the roof rail slot. Just make sure you slide it away from the openings.
