Home > Td5 > Front Washer jet replacement |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2504 |
Sympathies, I feel your pain, it is a real struggle.
Does your partner have smaller hands? As thought, when i did mine i brought a extra washer, a t-piece and extra house and a blanking grommet then refitted the washer jet either side of the original. Works well enough for me without spending a lot more money. Good luck Click image to enlarge |
20th Mar 2021 8:44pm |
Beero Member Since: 05 Jan 2021 Location: Southampton Posts: 21 |
When I got my defender both washers were totally blocked. I cleared them both with an airline. !00psi of air pressure is almost sure to clear them. Do you have a friend with a compressor? If not try your local car repair garage.
20th Mar 2021 10:17pm |
Guinness Member Since: 04 Mar 2021 Location: Scotland Posts: 53 |
unfortunately the head was very broken so i think that I have to replace the head, I think i might have to rely on luck to get bolt off!
20th Mar 2021 10:21pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5408 |
If you are replacing, and can afford it, upgrade to a decent one, don’t just put another bit of plastic there.
20th Mar 2021 10:50pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 890 |
When I did mine I changed it up and have three jets. No issues with mud, rain, sleet, snow or road grime at all.
Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
21st Mar 2021 4:20pm |
So i discovered my error. I bought this defender the beginning of this year and the front washer never worked, and assumed that it had previously. The jet was broken and so i replaced it, thinking that would be the magic fix, but unfortunately not. I then decided to follow the piping back looking for blockages until I realised that the previous owner had squeezed the washer pipe with the panel holding the speaker. once i rearranged the pipe it was all A-OK. A very frustrating fix but a fix all the same.
21st Mar 2021 7:09pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
When I changed mine I used a box spanner from a cheap set - something like this: https://www.toolstation.com/box-spanner-set/p59905 I replaced the useless OE jet with one of these http://www.csiparts.co.uk/en-gb/collection...jet/165077 and got the matching pump too. Not cheap, but far better than the original setup. Click image to enlarge |
22nd Mar 2021 12:43am |
Simmo107 Member Since: 06 May 2021 Location: Birmingham Posts: 12 |
Would you recommend the CSI washer mate? Being thinking about it myself. But spoke to anyone with one?
Thanks simmo |
6th May 2021 6:42pm |
I'm pleased with the CSI jet. It's been on over a year now. Expensive, but it works very well and looks good. I bought their pump too, figuring that the potentially 18 year old one was probably past its best.
6th May 2021 6:51pm |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 383 |
I’ve got the CSI washer jet and would definitely recommend it, is a great improvement over standard and uses the standard pump unlike some of the other options.
For the money it’s well worth it 👍 |
6th May 2021 7:15pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4348 |
I will throw my vote in for the Optimill washer jet... So Flippin’ good. I have had the standard single washer, dual standard washers and the Peugeot 405 (?) wiper blade washer jets and none compete with the optimill. The Peugeot ones got close though.
6th May 2021 8:14pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
Whoever took that picture, has done a fantastic job 🙄 CSI washer jet is fantastic. Well recommended. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
6th May 2021 8:39pm |
