Home > Maintenance & Modifications > Wolf door tops
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
Wolf door tops
Evening, have some of the above fitted to my 90, had them some years and now I'm getting the ANNOYING rattle. Will the channeling from series door tops do the trick ? Putting Dreams on Drives at JLR Solihull..
Post #892462 18th Mar 2021 9:35pm
northernerindevon
United Kingdom 1986 Defender 90 300 Tdi HT Nato Green
I can't advise whether the series channel will fit but I have the ex-military doortops on my 90 & suffered the same rattle - I'll testify it'll drive you mad.
In the end I bit the bullet and got the Garrison kit.
https://www.mudstuff.co.uk/products/garris...&_ss=r
Has everything you need and has solved the issue.
Silence is golden (at least silent doortops!)
Cheers, Paul
Post #892522 19th Mar 2021 9:04am
under_rover
2002 Defender 110 Td5 SW Oslo Blue
Like Paul, I went down the Garrison route from Mudstuff. Then days later this popped up in the for sale section
https://www.defender2.net/forum/topic74957.html?highlight=door
Might be worth an enquiry Cheers
Laurie
90 rebuild thread - https://www.defender2.net/forum/topic62909.html
Post #892529 19th Mar 2021 10:02am
Oldowner
I have used Woolies channel in Wolf door tops with excellent results, no rattles, glass fit snug to the channel and slides with enough resistance to hold the window from sliding back and forth.
Post #892690 19th Mar 2021 9:41pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Rather than shell out on the Garrison kit, speak with Shroppy on here.
He sourced a very similar product from somewhere and was selling some kits made up to do the windows.
Post #892754 20th Mar 2021 5:32am
