Home > Off Topic > Electric Jack
Electric Jack
A good idea or not?
Post #892642 19th Mar 2021 7:56pm
lohr500
Sort of thing where the battery will be flat when you need it most !!!
And I suspect there is more feedback on the load being applied through the handle of a traditional high lift jack, than pressing the button on an electric one.
So it gets the gimmick vote from me.
Post #892663 19th Mar 2021 8:55pm
markb110
A very good idea, anything that saves your back (getting old) is a good thing plus its very controllable.
However this will lead to a whole generation that will miss the thrill of potentially knocking out their front teeth, concussion and crushed hands...... Whistle
Good find.. Thumbs Up
Post #892666 19th Mar 2021 9:02pm
DSC-off
A must have item for the sort of person that uses a smart phone to control their winch.
Now, here's a thing for the mk2 version...
A smart phone controlled, Bluetooth, electric jack.
The price has just doubled Whistle
Post #892689 19th Mar 2021 9:40pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
I've pondered a similar idea using a wiper motor and worm drive gear.
However I'm not that technical so I filed it away in my brain as ' possibly possible '
Post #892755 20th Mar 2021 5:34am
With you in mind, they also have the... manual jack:
Although showing it being used with an electric battery powered impact wrench rather defeats some of the point of it?
Post #892759 20th Mar 2021 7:15am
miker
It looks to be a better thought out implementation of a screw jack, I like the fact that they sell it with 2 different types of battery mount available (Milwaukee & Dewalt 18v)
Winding it manually, while possible, would be painfully slow I suspect
Post #892840 20th Mar 2021 6:51pm
landy andy
A jack that was operated by a battery nut gun makes more sense to me. That way one power source does man6 jobs. If you jack vehicle then you are probably removing the wheel. If too lazy to manually operate, they are probably too lazy to use a breaker bar.
Post #892849 20th Mar 2021 7:20pm
markb110
Don't forget that when looking at the vid in the original post i would say that this jack is aimed at the off road racers.
Light and fast in use. Not so much being lazy but fast and efficient.
Think the UTV race at the recent King of the Hammers in February.
Alternatively think of the jacking belly plate on the Bowler Wildcat. No need for the weight of a Hi Lift Jack, nor the safety issues of getting under the vehicle with a bottle jack.
Like everything its having the right tool for the application...
Post #892894 20th Mar 2021 9:28pm
For that they have their "Dakar jacking system"
Post #892939 21st Mar 2021 8:07am
markb110
Thumbs Up
Post #892967 21st Mar 2021 10:39am
