Home > Maintenance & Modifications > LED Tail & Indicator Lights
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
Finally got around to fitting them -
Post #8906 23rd Mar 2009 7:02pm
CFB
Look smart, do they do them for the front too? Andy
Post #8912 23rd Mar 2009 8:29pm
nicks
they do, but the standard plinths are too wide for the panel, so i assume they wouldn't sit straight, but saying that i've never tried, i'll give it a go when i get a second
Post #8913 23rd Mar 2009 8:47pm
mlightfoot
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Nicks - They look amazing where did you get them from and did they require much interms of modification?
I want to get an LED kit but ideally a full set for all lights, like here: http://www.roverantics.com/
M
Post #8916 23rd Mar 2009 9:34pm
kljw
mlightfoot
have you tried JE Engineering, they do a LED kit for the diffy. Cheers
keith
puer claudius
Post #8920 23rd Mar 2009 10:00pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Is your reversing light led? and if so is the back face of it flush?
Post #8921 23rd Mar 2009 10:00pm
Martin
Site Admin
From the appearance, I'd say the reverse and fog are still bulbs.
A company on eBay is (was?) doing modified plinths to mount the larger lamps on the standard holes.
Post #8926 23rd Mar 2009 10:57pm
nicks
the fog and reverse are still normal lamps, not got around to changing them yet. The back of the lamps come with either a plug or just bare wires.
Post #8928 23rd Mar 2009 11:33pm
nicks
the plinths are just the standard fog/reverse plinths
Post #8929 23rd Mar 2009 11:36pm
Martin
Site Admin
Sorry, I meant that they do the modified plinths for the front Smile
On my 90 I've used the older style (pre-Td5) headlamp finishers, kept the standard plinths (they were all that was available at the time) and modified the body mounting holes and the finishers for the bigger lamps:
Post #8930 23rd Mar 2009 11:41pm
mlightfoot
Thanks - Where did you get them from?
Post #8937 24th Mar 2009 7:39am
beetroot
I have gone with the clear LED's they come with plugs that fit straight on to the factory loom, and you can get adaptor plinths that mean you dont have to drill new holes in the back body. When Land Rover did the SVX they could not get the indicatiors to work which is why the SVX has led's on the rear except for the indicators which are normal bulbs. People cleverer than Land Rover have now worked it out so you can have all LED's.
Post #8990 24th Mar 2009 9:38pm
Sonic3d
Can someone please let me know who sells the led reverse led light as i want some to fix to the underside of the rooftent when unfolded to light up the tailgate area Thumbs Up
Post #8992 24th Mar 2009 10:26pm
mse
Where did you get the LED units that are a direct replacement? im not sure if i like them, but am tempted. I assume it needs a new relay
I will add though that Land Rover could get the LED indicators but didnt for a few reasons, one like everything on the SVX is compromise 2 is servicability apparently (so you can easily go an get the bits) Mike
Post #8993 24th Mar 2009 10:31pm
nicks
i can supply the indicators, clear or amber lens' - i prefer the coloured ones. i get them from the manufactuer that supplies us with other led lamp units, so as we buy in bulk we get better discounts. i changed the relay to an electronic one so the indicators flash normally.
Post #8997 24th Mar 2009 11:18pm
