![]() | Home > Technical > Some help needed or pointing in the right direction.. |
| Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750
Evening all .. wondering if anyone can point me in the right direction.
2001 TD5 .. not started since last September.was awaiting a. New rear cross member ..long story .. Anyway battery in today having replaced all the filters went trough the priming process all the right noises fuel pumping etc .. At the end of the process went to start .. pop from under the seat and nothing no priming .. checking all the fuses under the drivers seat all ok . The second relay Click image to enlarge buzzes on Turing the ignition then stops .. no power no lights . Dash oil light etc come on but nothing else .. Any help would really be appreciated Thank you |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385
I’m only guessing, but I’d swap the relay out. and or check all earths. QRZ 2e0vpf
It was initially fine and primed ok however nothing now apart from very weak dash lights ...
| jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 405
I’d be looking at the main relays then if you’ve got nothing at all
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857
battery connections clean and tight?
Yes mate .. whole system initially primed ok but as soon as I turned it to start it didn’t
Thank you |
| Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727
So its not even turning over? Check your earth strap on the gearbox maybe? 2005 Td5 90 XS
1989 V8 110 CSW |
No like I said all initially went ok .. primed and all good . Turned the key to start .. pop from under the seat and all dead . Have dash lights as in oil etc .. however nothing else .. no hazards no lights
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986
Have you physically checked if the fuses under the driver seat have power to them.
| MichaelE Member Since: 18 Jan 2020 Location: Crawley West Sussex Posts: 155
As already mentioned, check the cable from gearbox to battery -ve. Don't just look at it and yank it to see if it's tight. Remove, clean, refit. I had 6 weeks of misery trying to fix a similar fault - partial electrics and no start - outside in the eternal rain of autumn 2019 whenever I had the time and felt up to it. I left the wipers turned on whilst I crawled underneath trying connections and listening for the wipers to come back to life. The gearbox cable was as tight as. But when I bent the terminal a bit, wipers came alive. Bent it back, they stopped. Almost had tears of happiness mixing with the rain. I heard the same crack as you when it first died.
When I disconnected the cable for cleaning it looked ok and I would never have thought it could have been the problem but it certainly was. |
Thanks mate will do
Just to thank everyone for the input on this .. problem solved .
Suffice to say the original battery was reading 12.9 so my assumption was that it was ok however slow to accept a charge of any sort . Checked the relays fuses and earth straps all good . Ordered a new battery as that was the plan anyway.. fitted this morning and she fired up first go .. thank you all .. Case of knackerd battery it was dropping to 8.7 when the ignition key was turned .. |
And thank you for letting us know. It all adds to the font of knowledge. Or pit. Deep, dark, bottomless pit........
