![]() | Home > Site News & Feedback > create/edit post: no photo panel |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6691 ![]() ![]() ![]() |
What device - have you tried on another device/browser?
I have given you some extra gallery space in case it is that which was the problem. ![]() ![]() |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1124 ![]() ![]() ![]() |
Thank you! Seems I had reached the end of the internet
Ok, this is weird... The problem persists but it seems to affect only certain files -
![]() When I try to upload something important, it's not added to the gallery or panel ![]() When I added the above screenshot yesterday it worked fine, so I thought the problem had gone. I tried various files but couldn't find a pattern so far. Also it's the same from another Mac with different OS version. It did work from the main Mac two days ago with a file from the same set (same format, same name pattern, same toolchain). No update of my software since then. Any idea what I could try next? Can you see any error messages in an upload log? |
Files or images?
If images, perhaps the image size is enormous and the server isn't receiving it quickly enough, or it doesn't carry out the processing (resizing/thumbnailing) to protect other server tasks. ![]() ![]() |
image files
![]() My images are all scaled down befor I upload them (I have a workflow stripping them of some EXIF data and adding that little watermark). It's usually 1000px wide JPGs with around 100 - 300 KB. To cross check I just uploaded an 8Mpx, 2.4 MB file - no problem ![]() Click image to enlarge |
update: problem has something to do with the file name
![]() I can upload the same image when it's named "IMG_5212 - tarp bag_csw.jpg" but not "curtains – 01_csw.jpg". I was about to write "I have no clue why", when I noticed the hyphen in the bad name is a "–", not a "-" ![]() Replace/remove that dash and it works ![]() When I said I'd used the same toolchain that was correct, but for the "curtain*" files I used an export function of iPhoto where it takes the album name plus a sequence number and puts the dash inbetween. I never noticed before that it was not a "-". Been using iPhoto since 2003... ![]() sleeping better now ![]() Frank |
Great detective work, thank you!
I now have a test file called "curtains – 01_csw.jpg" ![]() ![]() ![]() |
Fixed
Fixed? Now that I have manually renamed 1347 files ?? - no just kidding.
