Home > Maintenance & Modifications > I have cut something off I shouldn't have....HELP!
MarcusM
2007 Defender 90 Td5 HT Keswick Green
Hello all
Whilst taking off an old steering guard that was rusted solid to replace with a new ORE one I got a bit carried away with the angle grinder... As a result I have cut through two bolts that in hindsight look quite important to holding my Defender together.
One of the issues I foresee is I cannot seem to see the other end of the top one on each side...
Any help would be much appreciated plus what replacement bolts I need.
Thanks in advance
TD5 Defender 90
 Keswick green 2007 Defender 90 TD5
Post #891888 16th Mar 2021 5:42pm
Panhard rod brackets on the offside, two bolts:
    FC112326 - (1/2UNF X 6.1/4")
    FC112246 - (1/2UNF X 4.3/4")
From the 2007 on parts catalogue, and, yes, they really are UNF bolts on a 21st century vehicle!
Since the panhard rod is only fixed to the chassis at the offside, it is probable that the bolts on the nearside only held your steering guard.
Post #891902 16th Mar 2021 7:00pm
MarcusM
This is amazingly helpful- thanks BlackWolf really appreciate it Keswick green 2007 Defender 90 TD5
Post #891946 16th Mar 2021 9:03pm
Oldowner
They aren’t UNF, they are M12 starting from two years into the 21st century.
Post #892023 17th Mar 2021 6:59am
dorsetsmith
They aren’t UNF, they are M12 starting from two years into the 21st century. o no they are not
Post #892027 17th Mar 2021 8:04am
As noted in my post, I am just quoting the parts list. This clearly states the numbers I gave as applicable to 2007 on vehicles, those part numbers are UNF.
To resolve this I have just had a look at my 2007 2.4 110 and the Panhard rod bracket bolts are definitely 1/2" UNF, confirmed both by bolt head markings and AF measurement, and not M12.
Post #892050 17th Mar 2021 10:58am
Romadog
Post #892079 17th Mar 2021 1:08pm
Oldowner
Try ordering a set then and see what Land Rover provide:
https://www.brit-car.co.uk/product.php/145...anged_head
https://www.brit-car.co.uk/product.php/145...mm_flanged
Post #892154 17th Mar 2021 7:08pm
Oldowner
Post #892155 17th Mar 2021 7:14pm
Fair enough, but it doesn't alter the parts list and doesn't alter what is on my vehicle. I suspect that it is another cost-cutting exercise by LR.
Post #892158 17th Mar 2021 7:19pm
Martin
Site Admin
https://www.lrworkshop.com/parts/FC112326
https://www.lrworkshop.com/parts/FC112246
LR list these (or have listed these) as 1/2 UNF. Even the matching nut FY112056 is listed as 1/2 UNF on the 2007 on diagram:
https://www.lrworkshop.com/diagrams/land-r...s_44790#21
However these are all M12, the part numbers decode like this:
FC               1     12   32                 6
Fastener type  METRIC  M12  Length/5 = 160mm   Variant/Finish
Similar for the Nut - xx112xxx is an M12 nut
Td5 and earlier are definitely 1/2 UNF, this is up to 2006:
https://www.lrworkshop.com/diagrams/land-r...s_52609#20
Part number e.g. BH608381 decodes as:
BH               6      08            38              1
Fastener type    UNF    x/16ths       x/8ths          Variant/Finish
Bolt Hex?               inch = 0.5"   inch = 4.75"
Another case of LR copying the parts sheet over to the Puma, but in this case only changing half the info (the part numbers and not the description).
http://fuddymuckers.co.uk/tools/lrfasteners.html
(Yes I've been wrong about this in the past, now corrected)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #892161 17th Mar 2021 7:43pm
The part number decode is interesting. Curious that my '07 Puma definitely has UNF fasteners!
The only consistent thing is the inconsistency. Rolling with laughter
Post #892185 17th Mar 2021 9:01pm
MarcusM
Thanks for all the replies guys- I’ve ordered a set from YMrit
Marcus Keswick green 2007 Defender 90 TD5
Post #892277 18th Mar 2021 10:23am
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
If this was a social media post I'd be saying 'I was today years old when I discovered this'.
Absolutely brilliant bit of info - I've been looking at parts books for 30 odd years and never ever knew or suspected that there was a coding in the number.
FC               1     12   32                 6
BH               6      08            38              1
 JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #892311 18th Mar 2021 12:20pm
I notice also that the metric parts are flange head and the UN parts were not. Again I suspect that this is financially-driven since it eliminates the need to stock (and manage the stockholding of) and fit washers, which in volume manufacture must make a worthwhile difference.
Post #892330 18th Mar 2021 2:10pm
