![]() | Home > Technical > Windscreen to roof seal(s) |
| windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311
I bunged mine down with the closed cell foam strip and tigersealed it. unconventional but worked really well.
| Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306
I seem to remember mine had inner and outer seal.
| Bingo Member Since: 27 May 2020 Location: Moscow Posts: 84
There are many options for modifying the seal, but I ordered the original ones and I wonder where the second one is installed (made of porous rubber)
And where is the outer seal attached - along the leading edge of the windscreen frame? “A word of command has made these silent figures our enemies; a word of command might transform them into our friends. At some table a document is signed by some persons whom none of us knows, and then for years together that very crime on which formerly the world’s condemnation and severest penalty fall, becomes our highest aim.” — Erich Maria Remarque |
| Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 878
MTC6568 is stuck to the top of the windscreen frame using the self adhesive strip on the seal, it's position is variable depending on who fitted it in my experience. The photos in this listing should give you an indication: https://www.ebay.co.uk/itm/Land-Rover-Defe...3511309192 1985 127 V8 Build Thread
Series 2 109" Series 1 80" |
Thank you very much! — Erich Maria Remarque |
| All times are GMT |
