![]() | Home > Modifications & Maintenance (L663) > BREMBO 6-Pot Brake Upgrade |
thepetrolhead Member Since: 30 Jul 2013 Location: South West Posts: 247 ![]() ![]() ![]() |
Anyone upgraded to BREMBO front brakes, calipers, discs?
As fitted to V8/P400. Does anyone know if these are the same part numbers as RR Sport. Look the same. ![]() Click image to enlarge RR Sport Caliper ![]() Click image to enlarge Land Rover caliper. FFRR? ![]() Click image to enlarge L663 20" alloys ![]() Click image to enlarge L663 22" 5098 alloys Last edited by thepetrolhead on 31st Dec 2022 10:50pm. Edited 1 time in total |
I have the following part numbers.
RANGE ROVER L405 SPORT L494 OEM LAND ROVER RED BREMBO PART NO: 20A6470500 / 20A6470600 / LR139244 OTHER REF. NO. LR049115 / LR093886 / LR049117 / LR093886 Was hoping someone would be able to confirm that they are the same part as fitted to L663 Defender. I have a friend who is checking. If I get confirmation, I'll update this listing. Whenever I eventually get my new Defender L663 Hard Top, I want to upgrade to BREMBO front brakes. As fitted to P400/V8. I suspect, someone has already done it. |
SCP73 Member Since: 27 Feb 2021 Location: Essex Posts: 16 ![]() ![]() |
@thepetrolhead
I would certainly be interested in the MY22 P400e red version. They do look really good behind black/grey wheels. Certainly an upgrade SWMBO has said she would like. 1992 - Defender 90 1997 - Discovery 2015 - Disco Sport (only 1 child) 2018 - Merc V-Class (3 Children and the mutt) 2020 - Ordered 110 X-Dynamic HSE MY21.5 (hoping big enough for the family) 2021 - MY21.5 Cancelled by JLR, MY22 ordered, awaiting dates :/ |
Yes. My 21MY also "un-slotted" by JLR.
Now MY22 with some additional options. Still awaiting new build date. |
Babadook Member Since: 01 Feb 2021 Location: Lugano Posts: 3 ![]() ![]() |
22" has big caliper 6 pot with front 380mm disc and back 365mm
20" has normal caliper 4 pot with front 365mm disc and back 350mm |
I have been told these are the same
Part Number as L494 Range Rover Sport. Please check before ordering. When I do mine, I'll update the post. ![]() Click image to enlarge ![]() Click image to enlarge |
Andy S Member Since: 28 Dec 2020 Location: Lymington, Hampshire Posts: 66 ![]() ![]() |
Can the standard Defender caliper bracket be used or is there one specifically for these calipers?
You can buy refurbished one's off Fleabay but it's the brackets that may need investigating unless you know otherwise. |
Got a Land Rover tech friend investigating.
Will update will all the part numbers once known |
Any news on this yet?
jackie Member Since: 10 Aug 2021 Location: UK Posts: 2 ![]() |
Sorry to hijack this thread….
I am thinking to go for D250. However, since it comes with 2-piston caliper with 349mm disc. I don’t know if it is sufficient to stop the 2.4tonnes defender. So, for existing D200/D250 owners, can you advise if the stock brake is good or I shall opt for D300 which has 4-piston caliper instead? Thanks |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3481 ![]() ![]() |
The brakes are pretty fierce, they are more than up to the job. 24MY 90 D250 HSE, Tasman Blue
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
More than sufficient on my D240 - they can take a bit of getting used to as they are very sensitive but I’ve no complaints about their stopping abilities - miles better than the brakes I had on both the L322 Range Rovers I’ve owned. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Thanks a lot for the prompt response.
Just a bit curious the difference between D250 S and D300 SE. The difference in $ is £6000. I only see the D250 is 50bhp down, smaller brake and a bit of interior difference. Why is the difference so huge in price? Still deciding between the two and don't know if I shall spend £6000 more for D300 SE. |
Land Rovers greed.
I went with D200 because I couldn’t justify spending an extra 3 or 4k for 50hp. 24MY 90 D250 HSE, Tasman Blue |
