Home > In Car Electronics > Puma 2015 fuse help
Page 2 of 2 <12
90 Dreamer
thanks guys, will have to investigate further when I have some time........loath to take it back due to previous Warranty timescales and Covid issues.........
Post #890668 11th Mar 2021 10:41am
Martin
Site Admin
Does your heater fan (blower) still work?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #890702 11th Mar 2021 11:37am
90 Dreamer
yes definately Martin as was bloody freezing yesterday..........
Post #890739 11th Mar 2021 2:18pm
DAZ110
Excuse for new radio upgrade..? Thumbs Up Wink
Post #890759 11th Mar 2021 3:33pm
90 Dreamer
only if LR warranty is going to stump up as its (was anyhows) perfectly fine
Post #890769 11th Mar 2021 5:05pm
90 Dreamer
DAZ110 wrote:
90 Dreamer, looks like centre dash panel out then to see the back of the radio. Crying or Very sad
Is it not the same as a normal single din and simply pull the unit out of the front of the dash??
If not then is there a 'how to' guide anywhere for removing the panel please??
Post #890821 11th Mar 2021 9:15pm
DAZ110
Yes, sorry, you can just remove the radio.
I was thinking maybe the wiring to the radio might be lost behind the dash somewhere.
Post #890833 11th Mar 2021 10:02pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Sorry for the silly question, is it a face off head unit?
Have you removed & refitted?
Post #890834 11th Mar 2021 10:03pm
90 Dreamer
Yes it is the std Alpine face-off and done many times without change.....
Post #890835 11th Mar 2021 10:04pm
Martin
Site Admin
If the blower's working then it's not a terminal left off the ignition switch.
Was the warranty work in or around the dash area?
If your clock, interior lights and instrument cluster are working ok (these share the radio's permanent 12V feed) then fuses wise it could only be Fuse 27 (5A) which is the Aux (key position 1) supply to the radio only.
If it's an Alpine then yes you can pop the head unit out of the cage if you have a pair of Alpine radio keys.
To remove the whole panel, take out the 2 Torx screws about 2/3 down - one each side.
Then get your fingers over the top of the panel where it meets the tray above the clock, and pull towards you. You will release the clips, then work downwards.
I'm sure there's a YouTube video or a thousand showing it!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #890837 11th Mar 2021 10:06pm
DAZ110
This might help if you want/need to remove centre dash panel:
https://www.defender2.net/forum/topic16968...dash+panel
Post #890838 11th Mar 2021 10:06pm
90 Dreamer
The warranty work was to replace the front foam seal / paintwork below the windscreen but not sure what they would / could have disturbed to cause this issue was just musing they may have removed and not re-installed correctly??
Post #890841 11th Mar 2021 10:12pm
90 Dreamer
So mystery solved today and now have a fully working radio........the 10A fuse in the rear of the headunit was blown
I was told on collection tht the battery had gone flat so presumably they have jump started it and managed to 'spike' the radio hence the blown fuse??
Post #891374 14th Mar 2021 5:15pm
DAZ110
Glad you got it sorted. Thumbs Up
Post #891443 14th Mar 2021 10:34pm
Page 2 of 2 <12
