Home > In Car Electronics > Puma 2015 fuse help
90 Dreamer
Puma 2015 fuse help
Have done a search but couldn't find what I was after.........
Have recently had my Puma 2.2 returned from warranty / service work and have realised the radio isn't working and guess its a simple fuse if someone can pint me in the right directin please??
Everything else seems to work but will be checking more thoroughly at the weekend
Post #890532 10th Mar 2021 7:51pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Have a look at the under dash fuse box, fuse ID 43 (F44) should be 5amp.
Post #890578 10th Mar 2021 9:55pm
90 Dreamer
?? Only goes to F40 and have checked all as best as I can with no joy........
Presume there is a fuse in the back of the head unit??
Post #890589 10th Mar 2021 10:25pm
DAZ110
Is the clock and interior light working ? If they are then it shouldn’t be the fuse
as they are on the same fuse as the radio.
Post #890600 10th Mar 2021 11:02pm
90 Dreamer
That was what I thought and yes all working as they should.......
Post #890601 10th Mar 2021 11:03pm
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
Ignore this!
Post #890602 10th Mar 2021 11:05pm
Marks Landy
According to my Haynes manual F27
Post #890603 10th Mar 2021 11:06pm
90 Dreamer
Just thought that the truck was in for Warranty paint work on the bulkhead / screen surround and the lower windscreen foam seal
Guessing they may have needed to strip the dash to some degree to gain access?? If so then they simply haven't plugged it back in??
Post #890604 10th Mar 2021 11:10pm
DAZ110
Think it’s fuse 30 on 2.4 and 29 on 2.2 but not 100% certain.
If you have had work done then maybe you need to enter the radio code to get it working again?
Post #890605 10th Mar 2021 11:10pm
90 Dreamer
It has no power or illumination at all, nothing to do with even getting to a code stage......
Post #890607 10th Mar 2021 11:11pm
Marks Landy
Post #890608 10th Mar 2021 11:12pm
DAZ110
Look 2 down under your orange markings, says fuse 29.
Post #890609 10th Mar 2021 11:15pm
DAZ110
90 Dreamer, looks like centre dash panel out then to see the back of the radio. Crying or Very sad
Post #890610 10th Mar 2021 11:17pm
Marks Landy
Is the clock working?
Post #890614 10th Mar 2021 11:24pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
F27 5A is ignition switched
F29 15A is permanent live (also connected to clock and OBD socket)
Post #890615 10th Mar 2021 11:31pm
