![]() | Home > Puma (Tdci) > 2.2 EGR Cooler leak |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 693 ![]() ![]() ![]() |
I wouldn't worry about those temperaturers. Mine in the summer months runs between 94 and 97 and occasionally hits 100 on a hill.
BrunoJ Member Since: 14 Sep 2019 Location: Stavanger Posts: 81 ![]() ![]() ![]() |
Newer had such high temperature with normal driving, even on German highway last summer with about 30C outside and relatively high speed. But I assume up to 100-105, if not very long time, engine should survive without the issues.
Oldyellar Member Since: 04 Sep 2015 Location: Central Posts: 418 ![]() ![]() ![]() |
I've had it bypassed on transits with no issues same 2.2 engine
Just to close the topic. EGR cooler has been replaces. Went into small battle with my dealer, as they try to sell part with some crazy price. Finally was much closer to the "ok". And as I expected, although LR box, new part (and old as well) was just regular FoMoCo part.
Conclusion - when replacing the EGR, it is probably worth to replace the EGR Cooler, to avoid dual work. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2472 ![]() ![]() |
I’ve changed the EGR on my 2.2 with no subsequent issues or need to change the cooler, so I don’t think it’s something that should / needs be done at the same time. Noting the cooler does not need to be removed to replace the EGR.
Oldyellar. I thought removing the egr and blanking on a 2.2 was problematic as it works in conjunction with the DPF via the ECU.. So what was the process used on the 2.2 transits? |
The only I know there are some companies which has replacement of EGR Cooler together with EGR valve with their standard EGR replacement procedure. I can only assume that because EGR Valve has been replaced twice, and service has to wait for some gasket/sealing between EGR valve and cooler, while they allowed me to drive the car and I was at that time in mointains, reaching real winter, maybe I 'helped' to finish the EGR cooler.
I believe the "bypassing" we discussed here was about the EGR Cooler, not necessary about EGR itself. Then it is easy to do - just shortage of coolant pipies, to avoid them going thru the EGR cooler. I would assume these to parts are separated and their failure shouldn't corelate, but in my case it does and it's pity service didn't find it immediately, so I could avoid dubble work/cost. And EGR Valve story not finished. After 3kkm of replacement, and after few hundred km on the highway with high speed, I have again P0405 pending error and from time to time check engine. Exactly the same habbit like before. More funny - after long drive and ferry trip (I assume very wet environment ) I got P0404 error this time, but after clearing him few times it never pops up again. P0405 cames regularly, almost at any ride. I starting to think it could be an electrical issue rather than EGR valve itself, but not sure what should I check first... |
