![]() | Home > Puma (Tdci) > Nanocom for Apple Mac |
| Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039
Trailbear, your Mac is built to run windows as a secondary operating system, the tools to do so are on your Mac already, it just takes a little reading and some very simple steps to do it.
Once done, you will turn the Mac on and be greeted with a fully functioning Windows system laptop, no dodgy copies of windows needed, it's free. You can swap between Windows and the Mac OS very easily, so don't be put off by thinking you've lost the Mac abilities, you haven't. Once installed, your Mac will act 100% like a windows laptop. You can do this by following either of these links or get someone to sit with you whilst you do it For windows 7 install https://support.microsoft.com/en-us/topic/...21eb58ec6f For windows 10 install https://support.apple.com/en-gb/HT201468 Here's a video showing the process; I've used Windows machines for nearly 20 years and only now do I use Macs as it's just easier and if I need a windows program, I just swap over on the MacBook, it's the best of both worlds imho. |
| trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 405
Right, I’m gonna give it a go, one question though, should I use windows 7 or 10?
| macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1138
-del-
It does depend on which version the Nanocom prefers to run on? If you want to do this for just this program then go with what it is suited too. Win 7 will use a lot less space ( I think it's 16gb ) over windows 10 ( I believe mine is 48gb to include space for updates ) Balvaig's point about back up is good too. |
Once again, thanks Gentlemen.
Yep, well that’s not good, my Mac with it being new apparently comes with apples own processor
Which doesn’t support Windows....brilliant. |
| Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737
The wonders of modern technology
Technology was supposed to make life easier and better. Most of the new Defender problems appearing in the forum seem to be technology based. Never had these problems with my Morris 1000. |
So frustrating but I never gave it a thought that it may not work with a Mac, seems to be
a rather expensive limited bit of equipment for me😫 |
