![]() | Home > Technical > Newbie questions & difficult transfer gearbox question |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3725 ![]() ![]() ![]() |
The year means it’s a 2.2. Also the log book should tell you. It’s about 120hp from memory. Not sure on the transfer box, was it new or recon?
Jazz Member Since: 10 Mar 2021 Location: Kenya Posts: 6 ![]() ![]() ![]() |
Thank you!
The "new" transfer box was bought second hand and is supposed to be a original Land Rover spare part (according to the mechanic) |
Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 128 ![]() ![]() ![]() |
Sounds like the transfer box ratios are out. I believe that you should have a 1.2 gearing in the transfer box could be a 1:1 ratio they have put in to cause that behaviour or have they disturbed something in the engine causing a loss of power ???
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17852 ![]() ![]() ![]() |
The transfer box would originally have had a label on it showing the ratio, the label would be located in the vicinity of the oil filler plug by the handbrake drum. A 2014 Defender should have a 1:1.2 ratio box, which is different to all earlier models. It is possible that you have been supplied with the wrong type.
Be aware that the label is often missing on older boxes however. |
Thanks for your input! They definitely didn't touch the engine or anything else. I was there the whole time watching and trying to understand what's happening. The mechanic only removed the transfer box and put the replacement second-hand one in. It must somehow be caused by the replaced transfer box. Am I understanding it correctly, that you are saying there is a ratio setting inside the transfer box? So the box would need to be opened to check that setting? |
Thanks also for your help! I found the label on the current box and it says 1.211 (see attached photo) In about 2-3 weeks I can go to the facility where I am storing the old transfer-box. I don't remember having seen a label on it but in case there is one, I can check what ratio the old one had. edit: Somehow attaching the pic doesn't work. Give me a second, I will upload it and post the link edit2: I uploaded the picture, please see here: https://ibb.co/NrnkzP4 |
That should be the right box for the vehicle. Perhaps the one that came out was wrong.
If the label is missing it should be possible to check the serial number of the transfer box online, there are various sites which list serial numbers and ratios. It is very odd that just changing the transfer box has caused such a massive difference in drivability. |
Have a look on Ashcroft transmissions website they have a calculator to look at the differences in rpm speed and gearing all depending on transfer box ratio. It is possible that somebody’s has installed the 1:1 gearing in the transfer box you got as a replacement
Both your input is so incredibly helpful! I will check the ratio of the old box and also have a look on Ashcroft transmission's calculator. Doing all that will definitely take some time though. I just had a brief look at the calculator and it needs a lot of information that I need to confirm/find out first. Once I get the results, I will update you!
In the meantime: Does this issue sound like it's just a matter of my personal comfort/enjoyment or does it sound like something could be seriously wrong? In other words: If I continue to drive like that, do you think the ratio-issue (e.g. possibility that a different ratio/gearing is installed) could cause damages? I have a few longer distances to drive within the next few days, that's why I'm asking. |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 857 ![]() ![]() ![]() |
Have you ruled out that the handbrake isn't dragging? If you have only done short journeys the it might not get hot enough to smell.
Very interesting point! In addition to changing the transfer box the mechanic has played around with and adjusted the handbrake.
Do you know is there a way for me to check whether the handbrake is dragging without opening something up? |
jack up a rear wheel and spin it by hand with the handbrake off. It should turn freely (gearbox in neutral). While still spinning the wheel get someone to pull the handbrake a click at a time. You should get a definite engagement after a few clicks.
The easiest way might be to slacken off the adjuster (on the back of the handbrake, between the backplate and the transfer box) and go for a drive to see if it is better.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5971 ![]() ![]() |
Drive it then feel for it being REALLY hot afterwards |
