|  | Home > General & Technical (L663) > Expedition Rack - Remove "Aero Bars"? |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018      | Is your issue you don't want them interfering with the view or is it that they foul the folding roof?
 If the latter, then this is currently in play: SSM 75250 - L663 Opening Roof Panel – Does Not Slide Open 29th January 2021   Click image to enlarge | ||
|  7th Mar 2021 9:35am |
| Chioti Member Since: 03 Jan 2021 Location: NJ Posts: 25    | It’s interfering with the view that I’m concerned about. 2021 Defender 110 X-Dynamic HSE, Eiger Gray, Black Folding Fabric Roof | ||
|  7th Mar 2021 12:05pm |
| shawnpalmer Member Since: 29 Sep 2020 Location: Cumming Posts: 28      | We were able to slide some of the bars around. I think there is a tort bolt under the rubber strip on each end. I think you could remove them by taking the front off the rack and sliding them out, but never tried it or even thought about that. Let us know. | ||
|  8th Mar 2021 4:09am |
| Chioti Member Since: 03 Jan 2021 Location: NJ Posts: 25    | shawnpalmer, In a different thread you mentioned removing your rack several times. It sounded like you removed the 12 screws holding the rack to the feet and then loosening the screws on the feet in order to slide them off the track. Is that correct?
 Also, how long does it take start to finish assuming only myself doing it (being quite handy). Thanks! 2021 Defender 110 X-Dynamic HSE, Eiger Gray, Black Folding Fabric Roof | ||
|  8th Mar 2021 1:23pm |
| shawnpalmer Member Since: 29 Sep 2020 Location: Cumming Posts: 28      | No more than 15 mins if you have help lifting the rack on or off. It’s pretty easy. 13mm box wrench is what you need. | ||
|  8th Mar 2021 2:07pm |
| Andy_W Member Since: 17 Jan 2021 Location: Berkshire Posts: 11    | You need to loosen the front bar and slide it back. Then there are two bolts that can be removed and slide the front part of the frame off. The all the cross bars can be loosened and slid off.  Not a quick job so I would just shut the roof blind and leave as it is   | ||
|  8th Mar 2021 8:39pm |
| Posting Rules
