Home > Technical > Brake pipe material and diameter?
Hufflepuff
I need to build a complete brake pipe system for my '89 110, and I am a little confused by the all the options, I wonder if anyone could clarify things for me please?
The vehicle is not very 'standard' anymore, having had a rear disc conversion on the Salisbury axle, and fitted with the more up-to-date vented front discs and calipers.
I have looked at the complete system from Pioneer 4x4:
https://pioneer4x4.com/collections/complet...-1983-1990
but I already have the extended flexible brake fittings from Gwyn Lewis, and being a disc conversion I suspect that kit wouldn't fit. Plus - I think I would prefer hard lines rather than flexible ones, I might just be old fashioned but it seems to me having them rigidly fixed to the top the chassis rail is a nice and reliable setup.
Similarly the pre-built kit from:
https://automec.co.uk/products/brake-pipe-...-wagon-rhd
is unlikely to fit due to the disc conversion
My Father has lent me a good quality brake pipe flaring tool and pipe bender, so the next option is construct it all myself, and I see that I can get 'coils' of 3/16" copper-nickel from Automec, which I understand is the size used on Land Rovers?
https://automec.co.uk/collections/brake-pi...l-imperial
What about the fittings? Automec sell fitting kits in metric and imperial at:
https://automec.co.uk/collections/fittings...ssortments
RallySteve stated (https://www.defender2.net/forum/topic77086.html) that the fittings are metric for the Defender - but if that is the case I am confused why Wrights Auto Supplies selling a kit which uses UNF fittings?
https://www.wrightsautosupplies.co.uk/prod...-in-brass/
Most of these retailers off both pure Copper, and a Copper/Nickel mix (Kunifer I think its called?). I gather the copper option is a little more flexible and so easier to bend, but then what is the benefit of the Copper/Nickel mix - a bit more corrosion resistance and less work hardening?
Cheers!
Chris. 2005 Td5 90 XS
1989 V8 110 CSW
Post #889730 7th Mar 2021 11:05pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
I recently re-piped my 1994 defender with Cunifer after a new chassis build. Fittings were metric. I know this because I got an M10 tap to clean out threads on my calipers for the Bleed nipples and this was the same for the pipe fittings if I remember correctly. Bizarrely brake pipe is imperial even though fittings have metric thread.
Post #889737 7th Mar 2021 11:32pm
Hufflepuff
Thanks for the reply I Like Old Skool.
That matches what RallySteve was saying, so that is good. I'm very confused by that kit from Wrights though, I wonder why they are listing it as having UNF fittings...? 2005 Td5 90 XS
1989 V8 110 CSW
Post #889743 7th Mar 2021 11:47pm
Retroanaconda
Kunifer is what you want, 3/16” diameter. All fittings are M10x1 as noted.
If you’ve got the standard rear disc setup and vented fronts then you’ve basically got the standard setup for a 1993 - 2005 (ish) 110.
Post #889744 7th Mar 2021 11:49pm
Hufflepuff
Right that is clear then. Thank you gentlemen, I shall get that ordered. 2005 Td5 90 XS
1989 V8 110 CSW
Post #889751 8th Mar 2021 2:13am
chip butty
United Kingdom 2006 Defender 90 Td5 CSW Java Black
Hi just a quick one.If you make your own pipes, check that the flaring tool will make metric ends.Imperial pipe for both, metric male fittings metric flare.Imperial male fittings imperial flare.
Post #889822 8th Mar 2021 12:51pm
