![]() | Home > Maintenance & Modifications > When to replace suspension? |
Scrumps Member Since: 24 Feb 2021 Location: Somerset Posts: 108 ![]() ![]() ![]() |
Leathers,
You have posted this on the NEW Defender (L663) area!! Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
Leathers Member Since: 14 Aug 2019 Location: New Forest Posts: 26 ![]() ![]() ![]() |
D’oh!
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1494 ![]() ![]() ![]() |
![]() You don't have to change the springs, if they're OK, not sagging, sitting level and not too rusty. Standard original spec springs are the best compromise for all uses in a Defender. Shocks, any good brand manufacturer, replace both on the axle at the same time. Standard length if sticking with standard springs. |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 171 ![]() ![]() ![]() |
Was it a main dealer looking for some money, or a trusted indie?
It was a trusted indie who was just letting me know I need to think about changing the shock(s) soon, and I wanted to check whether I should do the springs at the same time. I’ve had some great advice both here and in the correct Defender area! Thanks.
