![]() | Home > Puma (Tdci) > Fit Britpart DA7012 side steps to puma 90 |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
no as long has you have got the right set for your defender should be a straight swap
Hankysandal Member Since: 02 Mar 2021 Location: sussex Posts: 5 ![]() ![]() |
Thanks. You were right.
Not the best quality and they ride considerably higher than the originals. You get what you pay for is the motto. |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 942 ![]() ![]() ![]() |
Paddocks do quick to fit side steps that fit all year Defenders, no drilling required. They also sit at a height below the sill so they are actually useful as steps.
Seem reasonable quality for the price ![]() |
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 210 ![]() ![]() ![]() |
If the side steps are anything like the rear step I bought via Britpart then good luck.
Didn’t realise I’d bought a Britpart step until it arrived (via another supplier). I’ve seen stronger springs on clothes pegs..........what a let down (pun intended) Took it off as it wobbled about ![]() |
