![]() | Home > My Defender > My 110 MILLIE. |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1872 ![]() ![]() ![]() |
Good to hear
![]() 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11031 ![]() ![]() |
Yesterday i had a call from John regarding the pump as they were setting up the equipment to test a few pumps and what i wanted to do if they could not find anything wrong with my pump, i replied back by saying " if you can't find nothing wrong with the pump, then can you put it back to standard ( i had the pump upgraded ) as it's no good to me as it is " okay he said and he will get back in touch next week to let me know the outcome of the pump
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
I had a call from John regarding the injection pump, he said that there was nothing wrong with it
![]() ![]() This is not the outcome i wanted, so i will have to do some more homework now ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1887 ![]() ![]() |
Hey Clayton,
Sorry to hear you're puzzling with this. I sent my pump down to Electro Diesel and spoke to John a few times. When they did the pre-test he said mine was 15% below standard, then they tweaked it. I've been very happy with it. But I was puzzling over your symptoms. This is probably a really basic suggestion, which you or your indy will already have considered - but it's not mentioned. Did you change or check the vacuum advance pipe - the one that runs from the turbo to the fuel pump? When I first investigated mine, I found a couple of small-ish but significant holes where it had rubbed through against the fuel pipes. If there are small leaks here, it would stop the pump diaphragm giving enough fuel advance. At low revs, this might be more important and reduce your torque?? A few ifs and maybes in there... and like I say it's maybe too obvious a suggestion. EDIT: Lift pump? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Hi Don
Yes we did put a new Vacuum pipe on to make sure ![]() This is where the puzzle gets more interesting, so when the tweaked pump came off and my spare went on, the difference between them was chalk n cheese ![]() Your last paragraph sums it up perfect which seems to be happening to the tweaked pump, but putting my spare pump on with no other changes is what is so strange, it was like it was the tweaked one, but it's a totally standard pump ![]() I still think that there is something wrong with the pump that no one can find out what it is ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20912 ![]() ![]() |
Have you tried PF Jones? I believe they are diesel specialists that could maybe investigate? Although, I don’t know if that is what they will undertake but maybe worth a look?
That’s where my VCV came from, they do lots of diesel parts and stuff and probably repairs. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5321 ![]() ![]() |
I think its time for a second opinion, see if there is another diesel specialist and ask them to see if they can test it ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
I will do in time Procta ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
I did look them up and they only do the puma engine pumps as they do Ford transit pumps as well ![]() I did come across Dieselbob but i don't know anything about them ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Millie went in for another one of her 6,000 mile service on the Saturday just gone, all went okay and i got my indy to do a few other jobs that needed doing and she's all good so far
I got 2 new BFG's fitted to the front of Millie today
They're possibly next on my list, what size do you have?
