![]() | Home > For Sale & Wanted > Found thank you ...Dampers/shock absorbers |
You will notice a world of difference by just fitting new standard shocks, which are not terribly expensive. Darren
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
I fitted standard replacements and they are fine.
Circa £20 each. Rgds. Chris |
Jez676 Member Since: 24 Feb 2013 Location: North Devon Posts: 178 ![]() ![]() ![]() |
Do you mean standard as in genuine Landrover? Or standard as in britpart copies?
I think I also need to change the rear springs to something softer as well they are HD ones. |
Standard LR - definitely not Britpart. Darren
Where is the best place ie cheapest to buy genuine Landrover dampers from?
I had a quick look just online and they are £100 each?? |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2361 ![]() ![]() ![]() |
Armstrong are the old OEM manufacturers. They are very good value for money. Boge were the later OEM manufacturers.
Hi Mo,
So what you are saying is that I should look for a Boge damper set for my 90 and they will be exactly the same as LandRover genuine ones? That’s a result ![]() |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 528 ![]() ![]() |
Unfortunatley the word fine with regard to Defender damper selection is equally unsatisfactory as its use in a post coital conversation! Spend the money fit Fox(with boots) or Bilstein and you wont look back or bounce. |
In the words of the younger generation that did indeed make me LOL
![]() Unfortunately being in the world of self employment for not enough time to claim anything from the government through COVID, my finances are also post coital !! I would dearly love a set of Alive comfort springs and Fox racing dampers to level out the North Devon roads but finances are dictating either some used decent dampers or the best value for money new ones I can find. Or if it gets any worse I will have to walk around 😂 Thank you for making me smile though ![]() |
Bearmach do 3 year warranty dampers for not much money...
There's two ways I look at this. They are probably costing about 4 cups of rice and they can afford to keep swapping them in the 3 years..... Or they are actually going to last 3 years. Or if you like, they know that you've put up with crap dampers for ten years, so you 'll fit and forget these, never having to warranty them...even if they fail after a trip to Mozzers.. |
Jez, there's a set going cheap here:
https://www.defender2.net/forum/viewtopic.php?p=887814#887814 Ignore the fact that it says for a tdi - they'll fit straight on to your 90. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thank you for all of your help , I’ve managed to find some Koni heavy tracks at the right price for me.
Hopefully have them on next week and no more bouncing down the road !!! Cheers Jez |
