![]() | Home > Faults & Fixes (L663) > Can you get Stealth mode to work? |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1136 ![]() ![]() |
I can’t. Info says that when Stealth mode is enabled in the settings, the cabin lights should dim when the Pivi screen is switched off. My screen switches off but nothing else dims.
Using the voice command Stealth Mode ON or OFF just turns the setting to on or off. Surely that’s wrong. I think if I say Hey Land Rover Stealth Mode On, then it should turn the stealth mode on and dim the lights? Confused with this one! 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 ![]() ![]() |
U been working through the index and now at S?
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3503 ![]() ![]() |
I think they only dim during night time conditions. 24MY 90 D250 HSE, Tasman Blue
Experienced that on a loaner in the early 90s, very weird.
My Jaaaaag has stealth mode, one button to press and the nav blanks and it all dims down.
Maybe I’ll try it in the dark!! 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
My stealth mode works well, can’t even see mine
That’s more due to the curvature of the Earth. Maybe we should all become flat eathers.
