Home > Technical > TD5 won't start, no relay clicking
TD5AT
Netherlands 2004 Defender 110 Td5 SW Belize Green
Came home after a longer drive without any problems, car parked outside for 3 hours, tried to put it into the Garage for th night, suddenly won't turn over.
Ignition seems fine, all the right lights come on and I can hear the fuel pump. But when I try to start: 'nothing'. Not even the clicking of the relays!
Checked the fuses with a multimeter and they all seem fine. Checked contacts of the relays, and switched the yellow ones with the one from the light (main beam) which is easy to verify.
Update: worth mentioning, lights stay on when I try to start.
Also, with the hood open, I believe I can hear the solenoid clicking.
I guess starter engine is likely culprit?
Any idea what else it could be?
Thanks in advanced,
Christian
Post #887149 22nd Feb 2021 7:37pm
landy andy
Starter I would think. And assume you’ve shut all doors and bonnet, locked it with remote, wait, unlock, try to start, incase it’s the immobiliser.
Post #887168 22nd Feb 2021 9:18pm
TD5AT
I closed the bonnet and made sure the alarm was happy when I locked it.
Will leave it like that over night and try again tomorrow.
Wouldn't be the first time the Landy fixed itself over night, tough, the last time that was water related and today it was bone dry.
p.s. I also wonder if I should try to jump start it, just in case it is the battery (I only measured 11.88V with the ignition on). But given the lights don't go out when I start, I doubt it is the battery. Probably a bit low because I was trying to start and measure a couple of times.
Post #887170 22nd Feb 2021 9:35pm
Martin
Site Admin
Check the connectors are all secure on the ignition switch (instrument pack out - 4x screws - and look down) Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #887188 22nd Feb 2021 10:20pm
dorsetsmith
Check that you getting 12v from ignition switch to the starter relay coil ( 86 ) , the ground for starter relay coil ( 85 ) control from AS10 immobilisation unit only when un-immobilisation
Post #887205 22nd Feb 2021 11:37pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I've been in the same situation before, it turned out to be the small wire on the starter motor which connects via a spade connector. Crawl under the car and locate the starter, the small wire connector just needed a wiggle to make the connection again assuming that is the problem.
Post #887208 23rd Feb 2021 12:39am
TD5AT
Thanks for all the useful suggestions.
Will have a look at starter hunting for the wire tomorrow.
Post #887325 23rd Feb 2021 7:09pm
