Home > Maintenance & Modifications > Rear door lock barrel removal - no pin hole
wynn153
Not sure if I'm being dumb but I am replacing my rear door latch on a puma 90 and need to get the lock barrel out of the latch.
I have had a look online and it says there should be a pin hole to put a screwdriver in but my lock doesn't have that so I am not sure how to remove the barrel.
Anybody have any ideas?
Thanks
Post #886993 21st Feb 2021 8:07pm
Bev
Scotland 2003 Defender 90 Td5 CSW Oslo Blue
It’s definitely there. On the newer style doors the pin hole is not as visible as it’s is on older type doors. Having just gone through this change myself, I found the pin hole to be accessible from the inside of the rear door lock mechanism.
If you have the door lock off you need to look down inside the mechanism from the opening that the handle moves in. The pin hole might be covered in crud and dirt but it is there. You should see it behind the metal plate, Not on the outside door barrel itself.
I don’t have my truck here to take a photo sadly and nothing come up on google search 2002 Td5 | 90 County Station Wagon | Oslo Blue
2006 Td5 | 90 County Station Wagon | Tonga Green (Gone )
2002 Td5 | 90 County Station Wagon | Zambezi Silver (Gone)
Post #887000 21st Feb 2021 8:23pm
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Photo attached showing hole circled in red, not easy to find as Bev said,
Ashbyandy 👍
Post #887006 21st Feb 2021 8:32pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Had the same issue - as the guys have said, once you know what you are looking for......... Rgds.
Chris
Post #887035 21st Feb 2021 10:21pm
wynn153
Thanks a lot, very helpful.
Sorry for the delay
Post #890567 10th Mar 2021 9:16pm
SteveP
Thanks, a picture makes it so much easier to find. Very Happy
Post #905492 28th May 2021 3:51pm
