![]() | Home > General & Technical (L663) > Catalytic converter cover/skid plate? |
| Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1142
Set it to lower to access height on switch off. The thieves will likely have to jack up a vehicle to get access and I’m sure they will pick an easier target. I’m not even sure if the cat is visible from below? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy |
| davidblythe Member Since: 27 Apr 2019 Location: Cheam, Surrey Posts: 110
jacks are used in this area to remove cats, enough photos on our local facebook groups to know that this is the M.O. 1999 90 TD5 CSW
2006 110 TD5 HD Commercial |
| G4R1 Member Since: 17 Aug 2020 Location: Barnet/Limassol Posts: 131
Yes, jacks are used, clearly seen on CCTV. Lowering probably will just make the operation under the vehicle a bit more difficult.
The exhaust pipe is visible and easily accessible. One of these on the photo must be the catalytic converter. Click image to enlarge 3.0L MHVE D200 S Pangea Green+Black Pack Adv. + Off-Road and Family Packs |
| DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837
Daft question but would a guard mean the heat from the catalyst escape less easily and risk a fire under the car? Me = non techie so just a question that popped into my noggin.
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
If lowered and fully alarmed then moved with a jack the alarm motion sensor should trigger? 130's have feeling's as well you know
| All times are GMT |
