Home > Puma (Tdci) > Puma 2.2 EGR activation
Nigelhirst
United Kingdom 2014 Defender 90 Puma 2.2 HT Keswick Green
Hello all.
This is my first post here, so sorry if this has been answered before, but I’ve searched and couldn’t find anything.
I have bought a Draper EGR tester thing, with a view to activating the valve to clean it, before embarking on pulling it out if it doesn’t work.
Unfortunately the plug supplied with the Draper tester doesn’t fit, and the alternative Draper give is a set of 2 wire jumpers. This relies on you knowing which two of the five pins you need to put 12v across to operate the valve. The Haynes manual doesn’t have any information....
Thanks
Nigel
Post #886117 17th Feb 2021 2:24pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Welcome
Can't help with the Draper tool, but after about a year of ownership, and no strange noises after turning it off, my 2.4 suddenly made alarming "Chugga, Chugga, Chugga sounds immediately after turning the engine off. I discovered that this was the EGR going into self cleaning mode.
BAS EGR delete patch https://bellautoservices.co.uk/store/puma-...-road-use/ coupled with a 165bhp tune solved the EGR problem Thumbs Up Just because you're offended doesn't mean you're right.
Post #886121 17th Feb 2021 2:46pm
Nigelhirst
Thanks for that!
Mine has always made the ‘chuga chuga’ self cleaning noise, but it has stopped. Probably because the valve is blocked up.
To say there are ‘only’ 4 bolts to undo, it looks like a pig of a job to take off the old one...😱
Nigel
Post #886126 17th Feb 2021 3:16pm
williamthedog
Why don't you have a remap and have it deleted at the same time?
Post #886131 17th Feb 2021 3:53pm
Nigelhirst
Yes I will probably do that.
I've answered my own question.. Pins 1 and 5 (pin 3 is absent) activate the valve. Just waiting to see how long the cleaning lasts before it sticks again.
Nigel
Post #886139 17th Feb 2021 4:29pm
Ianh
I’ve done an egr valve replace on a 2.2, to be honest if you take it off have a new one to replace it, it’s a pierburg valve and you can get one for £100 inc the two gaskets , and that’s a gen OEM valve as used by ford and LR. Then see if you can clean up the old one, but to be honest once it has gone it’s unlikely it can be fixed and not worth the risk and going into limp mode a long way from home.
It’s fiddly but not technical, involves two bolts , two nuts and two studs, plus two cooling pipes and the electrical connector..
Need to get the heater diverter valve bracket out of the way and if you don’t have air con it’s easier.
So £100 plus four hours first time diy on your drive, approx 2 hours second time as you have the knack and know the process. Alternatively 2 hours for an Indy to do if you provide part. Just worth costing against an egr delete and tune package.
Post #886142 17th Feb 2021 4:56pm
Roy5695
You can’t simply remap the EGR out of a 2.2. Unless you remove the DPF and remap that out too... 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #886149 17th Feb 2021 5:31pm
Ianh
Just out of interest, what’s the interaction between the EGR and the DPF, I would have thought mapping the EGR out and closing it off would benefit the DPF as mixing exhaust gasses with air in the combustion generates more particulates for the DFP to deal with, so mapping it out and blanking it off would result in no exahaust gasses ever being mixed in combustion and therefore less particulates being created for the dpf to deal with.
I expect the map would be more complex if there are signals going to the ECU, but would not have expected the DPF to need removal.
Not saying it’s not true, just trying to understand why Smile
Post #886161 17th Feb 2021 7:21pm
Roy5695
Quite the contrary, with the EGR in place, less particulates go through the DPF as some of them are burnt twice!
Blanking the EGR and leaving the DPF in place would increase the fill rate of said DPF (due to none being recycled) and cause premature filling, causing the DPF to either block or regenerate more often.
The EGR also plays a role in the Regeneration process, something to do with the burn temperatures and being a safety device if things get a bit hot. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #886199 17th Feb 2021 9:56pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Roy, I think the recirculated gasses cause lower temperature combustion in the cylinder to avoid NOx creation. So you're probably bang on with the EGR enabling control of regen temps.
Post #886211 17th Feb 2021 10:24pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Roy5695 wrote:
Quite the contrary, with the EGR in place, less particulates go through the DPF as some of them are burnt twice! .
The DPF is in place since they modified thé combustion process (= lower temp = less NOx and more PM).
I'd better leave it like it is (originally) since they are developping test procedures for the MOT
Here in France, it changed in 2018 - now they measure if your DPF is functional (PM)
And they've already announced a more sophisticated test to come - which includes EGR and the rest (NOx ; HCO etc.)
They're gonna make us beg for electric cars
Post #886606 19th Feb 2021 8:53pm
