Home > Td5 > Rear step model
TafkaP
Rear step model
Does anyone know what rear step this is? Looking to get a stainless steel bolt set for it. Or black anodised.
Any advice be appreciated.
Post #885995 16th Feb 2021 11:12pm
Adammacky
NAS rear step and tow bar
Post #886007 16th Feb 2021 11:38pm
It looks like a standard LR NAS step but there are several different ones available from different manufacturers and they're all very similar.
Is it one that you own or a specific one that you want to buy?
You should probably be aware that if you're planning to use it as a tow bar then stainless bolts are not recommended because of their particular properties. Plated or even galvanised steel would be a better bet. Darren
Post #886055 17th Feb 2021 9:51am
Dinnu
As above ^^^^. Ideally grade 10.9. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #886157 17th Feb 2021 6:57pm
TafkaP
Thanks. It’s already fitted came with it. Think it was only fitted in November with new rear cross member.
Can grab some 10.9s out work easy enough. Might just paint them.
Most it will take on tow bar is a bike rack. Hoping as the step pulls bar out futher rom spare I will be able to fit a rack with no hassle.
Post #886224 17th Feb 2021 11:26pm
donmacn
I have one of these NAS steps, and a 265/75 tyre on the spare.
I still need to use an offset bike carrier to clear the spare wheel. I have one of these: https://www.maxxraxx.co.uk/bikes-racks/exp...le-carrier
My wheel is mounted to a swingaway carrier, rather than directly onto a door mount, but even still I don't think a vertical carrier will fit. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #886260 18th Feb 2021 10:44am
TafkaP
Mines is on a swing away too. Guess I’ll need to look at the maxis then. Cheers
Post #886361 18th Feb 2021 6:28pm
