Home > Td5 > Rear Wiper and Washer not working
joshgorham
Hi there, I have a 2002 110 csw, newly purchased so I'm all rather new to this, but my rear wiper and washer were working this morning and stopped working this afternoon. Are there any culprits that I should look at first? Im not sure I will be the most confident tearing out all the cabling just yet, but i'm happy to get my hands dirty to an extent!
Thanks! 2002 TD5 110 CSW
Post #885055 12th Feb 2021 7:39pm
landy andy
Check that the rear door is a neutral, and check the wires in the rubber boot from body to door. Does demister work ok?
Post #885059 12th Feb 2021 8:04pm
Martin
Site Admin
Check Fuse 10, it's the ignition supply to the rear door wiper motor relay and the rear washer switch.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #885068 12th Feb 2021 8:30pm
Beero
Check the loom inside the rubber flexi tube between the door and the body. I had one wire broken and a few others where the insulation had cracked on my 2005 TD5 Defender. It is repairable if you have a soldering iron and some shrinkwrap tubes.
Washer is probably just frozen up.
Post #885303 13th Feb 2021 5:26pm
joshgorham
Thanks for everyones suggestions, it was just a simple fuse in the end! i can now see out the rear of my defender, I now just need to troubleshoot the front washer not producing the goods! 2002 TD5 110 CSW
Post #885474 14th Feb 2021 2:34pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
These are the problems I had with the rear and front wiper/washer/motor system on my 2001 TD5 90
Front washer issues, non return valves and reservoir tank clean.
Front washer issues, more return valve issues.
Rear wiper motor issue.  Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #885511 14th Feb 2021 5:25pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Now that it is working this is fantastic mod for the rear wiper.
 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #885513 14th Feb 2021 5:42pm
Mo Murphy
You'll need to find out why the fuse blew. Chances are that the motor spindle is starting to seize up due to water ingress. If this is the case it'll be the first of many blown fuses until you strip the motor.
HTH
50 Shades of Pennine Grey
Post #885515 14th Feb 2021 5:55pm
MC84
On my rear wiper the magnet detached from the housing, as per my video. It didn't blow the fuse as the cable feeding the motor was so high resistance is couldn't draw enough current. After fixing the magnets and cable to the motor it appears super fast, well compared to how it was! Mike
Ford 100e 1959
Post #885517 14th Feb 2021 5:59pm
joshgorham
Thanks, I'll hold taking apart the wiper motor until it blows again, but at least I will be expecting it and will have a spare fuse at hand! And i have actually discovered your videos before mike! I suspect the front washer issue is the non return valve so i have just ordered some from bearmach and hopefully that will help identify the problem, and then hopefully I can improve it from there. Also I would have been far too scared to take apart the rear wiper motor if it wasn't for your video. I will get better as i go on, baby steps... 2002 TD5 110 CSW
Post #885555 14th Feb 2021 8:43pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Maybe your wiper was frozen? - it's been a tad cold of late. My front wipers were totally frozen to my windscreen which blew a fuse a couple of weeks back. My wife pointed out that this was supposed to be the vehicle that we could rely on in adverse weather conditions! - & we ended up taking her boring yet reliable car instead! Smile
Post #885556 14th Feb 2021 8:55pm
MC84
I'm glad they helped joshgorham 👍🏽 Mike
Ford 100e 1959
Post #885563 14th Feb 2021 9:51pm
joshgorham
Hi Mike, I think I remember from watching your videos that the non return valve for the front jet is located in the engine bay by the passenger footwell, is this correct or am I thinking of something else? The valve is arriving today so just thinking about fitting it!
Cheers,
Josh 2002 TD5 110 CSW
Post #885810 16th Feb 2021 8:25am
MC84
Hi Josh, on my 2001 RH drive 90 the front non-return valve is in the engine bay under the heater box, dangling. You should be able to see the pipes running into the bulkhead. Just trace them back from there. I cannot remember which is which ie lefthand is front or rear. It'll make sense if you have a look. On mine there was just a joiner for the rear. Someone else may have already been there though. The rear non-return valve is under the head lining on the passenger side above where the passenger sits. I've relocated this to the engine bay as well now. I hope this helps, Mike. Mike
Ford 100e 1959
Post #885813 16th Feb 2021 8:37am
