Home > Tdi > Injector Pump Breather Leak
BajanRover
1995 Defender 130 300 Tdi HCPU Alaska White
Lads and Ladies,
I own a 1995 Defender 130 and recently I’ve been seeing a leak coming from the breather hole at the top of the IP, at first I wasn’t sure what it was when I removed it from the IP using a 17mm socket, but after some research it figured out it was the Breather.
My question to you is what would make this leak diesel and is it a severe issue? Obviously my fuel consumption would go up because of this but how do I fix this? Do I need to remove the IP from the engine 😣😣😣.
I attached some pics of the IP in the engine bay for reference.....
Post #885005 12th Feb 2021 4:51pm
Retroanaconda
If it’s leaking out of the breather on the back of the boost compensator housing (below where the plastic pipe from the turbo joins) then it will be diesel passing the o-ring on the fuel metering pin. A strip and rebuild of the pump will be required I’m afraid.
Post #885050 12th Feb 2021 7:07pm
BajanRover
Thanks Retro
Post #885323 13th Feb 2021 6:44pm
BajanRover
Does the current leak have potential of becoming worse? Will i develop engine issues if i prolong the leak? The reason i am asking is because i use the vehicle for work and because of COVID 19 most places are closed where i live so finding someone to fix this for me will be a challange.
sigh....
Post #885326 13th Feb 2021 6:53pm
Retroanaconda
Mine had the same problem years ago and I ran it like that for a short period while I arranged a new injection pump, I had a rubber glove tied on to the pump to catch the diesel that leaked out. Assuming that your fault is the same it’s unlikely to have any major impacts but I still wouldn’t leave it too long.
Post #885350 13th Feb 2021 8:05pm
BajanRover
Thanks again Retro! Will do the glove idea until workshops reopen over here
Post #885580 15th Feb 2021 12:12am
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
You don't need a pump rebuild, we do a top cover reco here and that fix's the problem.
Post #906291 3rd Jun 2021 10:39am
BajanRover
Must the IP be removed from the engine to perform the top cover reco? Or can it be done still connected to the engine?
Post #906312 3rd Jun 2021 1:16pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Today i was looking for a leak somewhere around the crank breather and spotted that 2 rubber plugs where missing and 1 perished from the block around the camshaft area. I checked another engine and there was 2 that are perished. Took a photo of an old scrap engine. Think this my be the cause of the build of oil vapour on that side of the block. Has anyone experienced this, or know what Land Rover call them or even the part number. Thanks Craig
Post #911236 7th Jul 2021 5:16pm
Retroanaconda
It’s not a plug, it’s just sealant. They are drilling’s for the camshaft bearing oilways made during manufacture that are then plugged and filled with sealant.
Clean them out and fill with oil-resistant sealant.
Post #911251 7th Jul 2021 6:21pm
