Home > Maintenance & Modifications > fitting external wiring
jst
i am looking at adding some external wiring for rear roof/roofrack fitment. i also have a roof tent that has an interior light and solar panels fitted.
roof lights to go on rack and stay fitted.
the roof tent is on/off regularly as well, a bulkhead electrical fitting may be better suited? any suggestions? (solar wires and interior light)
Other than drilling a hole and passing the wire through with a grommet has anyone found a reliable weatherproof way of doing this?
where is the best place roof surface or rear? i presume rear but dont want the wires coming out a grommet and going up really, nothing too visible.
Can you cut the solar charge wires (2 of) and feed into a bullhead fitting? i guess they are shielded?
any help greatly apprecaited. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #884812 11th Feb 2021 9:13pm
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Have a look at 12 volt planet Thumbs Up
I’ve got a deck fitting to go on my roof at the rear Thumbs Up
Post #884849 11th Feb 2021 11:13pm
jimbo55
I’d be looking at MIL type connector, whilst they aren’t the prettiest things, they are sealed and can use a cap when disconnected.
Most of them just have a locking ring to keep the connectors in place so are easy to connect and disconnect
Post #884894 12th Feb 2021 10:13am
jst
thank you , will check both out Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #884897 12th Feb 2021 10:17am
donmacn
I've gone for both approaches - a gland and a plug.
The lights on the roof bar (permanently attached) are wired through glands on the roof. Blue Sea marine fittings.
Then, on the back, for more portable or flexible arrangements I've put a plug/socket onto the rear quarter panel. I decided that a fixed light would only shine in one direction, while this arrangement allows the light to be positioned wherever it's needed. The female end remains attached to the car, you can see the cover for it hanging in the door aperture.
When it's not in use it's just a discrete little black 'blob' on the back, and practically invisible to me now. (Photo credit to LRO magazine)
This way if I need other accessories I just fit a new plug to it and plug it in. This has been on the car, and completely trouble free for nigh on 15 years.
I fitted it on the rear quarter just because it was accessible at the time. You could fit it on the rear of the roof just as easily. Again it's a marine fitting.
These days, I think there are magnetic versions available which would be more streamlined, and which would likely be even more compact. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #884913 12th Feb 2021 10:54am
I generally use Bulgin connectors from the family linked below. These are waterproof and available with a wide range of different numbers of pins. They come in panel-mount and cable-mount versions, and sealing caps area available if you need to seal an unplugged connector.
I've used these, inter alia, for winch remotes for years, and have never had an issue of any kind with them.
https://uk.rs-online.com/web/p/industrial-...s/0483922/
Post #884919 12th Feb 2021 11:12am
