Home > In Car Electronics > Advice on running reverse camera cable
Cooperracer05
2003 Defender 110 2.5 TD SW Java Black
Hi team,
I have a new hifi with the 3" screen and a reverse camera.
Im going to mount the camera up high I think, above the back door where the sprayer is (that will be moved).
What is the best route for the cable for the camera? Where does the wire for the sprayer go?
Was thinking about going under the carpets and up the rear facing side window trim and under the headlining....
Is that the best way?
Post #884749 11th Feb 2021 4:56pm
Installing one of these is on my never-ending list of things to do but I do plan to go up the drivers side A pillar and along the inside edge of the roof. It's the shortest route but will require the removal of the headlining, which is one of the reasons I keep putting it off Rolling Eyes
The rear washer has a pipe to it rather than a wire, which comes in from the left/passenger side having followed a similar route up the passenger A pillar and along the roof. It's quite easy to move it that way slightly to clear a centrally mounted camera, probably without even shortening the pipe. Darren
Post #884757 11th Feb 2021 5:08pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
If you haven’t bought one yet consider getting a Bluetooth camera set up, you only need a local feed for the camera so no complicated routing of wires. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #884763 11th Feb 2021 5:36pm
Cooperracer05
thanks Darren - I am very much at risk of this sitting int he box for ages. The head unit took 10 mins to fit, but the hard work is the camera. I need to line the roof with sound deadening so might do both but then it all gets a bit overwhelming for someone as lazy as I!
Thanks Leamreject - I already bought a wired camera
Post #884766 11th Feb 2021 5:48pm
Cooperracer05
Is the headliner easy to remove?
Post #884767 11th Feb 2021 5:49pm
Dinnu
I installed the rear view camera under the number plate light.
Wiring went up next to the rear quarter windows and along the inside channel of the roof.
I had to pull out the rear quarter trim, the long piece of trim on the rear side of the headliner only. The front headliner i just pulled the 2 fir trees on the passenger door and had to undo the sunshade. My monitor is in the rear view mirror though. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #884768 11th Feb 2021 5:55pm
t's not difficult but is awkward and bulky. You have to strip out all of the upper side trims too, unfortunately. Darren
Post #884769 11th Feb 2021 5:57pm
donmacn
Well, just to reinforce what you think already, I put mine into the rooflining.
It's powered via the front cam, so the cable needed to get there, rather than down the A pillar.
One thing to think about though, with my 110 the supplied cable (rear cam to front cam) wasn't long enough and I needed to get an extension. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #884797 11th Feb 2021 8:09pm
Bish
2002 Defender 90 Td5 XS CSW Java Black
Use the Optimill reversing camera and integrated number plate from Mudstuff. Run cable along rooflining and down the a-pillar. I can fit one in about 2 hours. Dead simple.
Use the special cable from mudstuff to switch on the camera when the reversing light is engaged.
Post #884802 11th Feb 2021 8:22pm
nitram17
After the w pillar how did you get it to the HU?via the dash!
Post #904166 20th May 2021 10:27pm
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
I ran mine along the floor under the carpets.
I already had a dash camera on the back, did it whilst sound proofing it.
The cable comes down behind the rear speakers.
Fabio
Post #904184 21st May 2021 5:40am
