Home > Maintenance & Modifications > Defender 1993 Front Door Hinge Screws
Buckers
Hi, I am wanting to fit some replacement Wing Mirrors to my Defender, it has large headed Phillips Screw Heads.
Does anyone know what size screwdriver I will need to use so that it will be the correct size/fit please?
Thanks.
Post #884727 11th Feb 2021 2:05pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
If the hinge screw heads aren't Torx then they're more likely to be PZ4 rather than Phillips.
Post #884736 11th Feb 2021 3:09pm
Dinnu
Indeed, they are Pozi screws, PZ4 (we are talking about the screws that fasten the hinge to the bulkhead and the doors.
The screws that fasten the wing mirror are smaller, I think PZ2 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #884740 11th Feb 2021 3:33pm
Buckers
Thanks to you both.
Definitely not Torx, I will look into getting PZ4 & PZ2.
I will measure beforehand.
All the best
Post #884742 11th Feb 2021 3:47pm
Dinnu
Btw, to access the screws for the mirrors, you only need to undo the door side bolts.
The nuts are not captive. But you may be able to keep them from rotating bu using a 13mm open ended spanner to save you removing the door card. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #884771 11th Feb 2021 6:07pm
