Home > Maintenance & Modifications > DCPU Spare Wheel Carrier
Page 2 of 3 <123>
Roy5695
I’ll see if I can find it and get back to you Thumbs Up it’s been a while since I’ve seen it. I had the spare on the roof for a few years before fitting the wheel carrier. It’ll be in the shed somewhere. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #883879 8th Feb 2021 12:11am
steve E
Wales
Many Thanks Roy
Post #883886 8th Feb 2021 8:25am
Roy5695 wrote:
steve E wrote:
Sorry to ask but does Anyone have the plastic spare wheel securing bolt they would like to sell.
I can’t find the part online and my spare sits on the tub floor.
Plastic? Mine secured with a threaded bar attached to the bulkhead. Had a metal disc with foam on it and a wing nut.
Mines a MY13 and came with this:
A plate, an aluminium spacer and a spare wheel nut:
I moved mine from this position, as if you tighten that nut too much - or actually just enough to take the slack out then the tyre ends up getting marked by the sharp edge of the tub:
I fitted some edge protector as a short term solution:
Post #883911 8th Feb 2021 12:14pm
That is exactly what mine came with (my spacer is steel, not aluminium though, and I suspect that yours probably is too). I have sometimes wondered what is the purpose of the two slots in the disc, any idea?
I have also removed the bits fixed to the bulkhead since they stick out far enough to be a real nuisance if you don't use them for the wheel.
Post #883918 8th Feb 2021 12:49pm
I'll stand corrected on the spacer ~ it's a while since I last handed it and jumped to the assumption from my photos Thumbs Up
No idea about the slots ~ another LR mystery?
Post #883924 8th Feb 2021 1:42pm
steve E
Wales
Thanks guys
At least I know what it looks like 👍
Post #883933 8th Feb 2021 2:32pm
Roy5695
If you have alloys you don’t get the spacer. And it was indeed a spare locking wheel but holding the wheel in, not a wing nut. That was on my roof wheel mount. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #883993 8th Feb 2021 6:50pm
astroarcadia
I have one taken off my 90PU.
PM me if you want it.
Post #885100 12th Feb 2021 9:43pm
astroarcadia
By that I mean there threaded bar with mounting plate, the retaining disk and the spacer. The nut is just a standard nut.
Post #885104 12th Feb 2021 9:47pm
What do you mean by "mounting plate", in my DCPU what I would call a mounting plate is riveted in.?
Post #885146 13th Feb 2021 7:35am
Roy5695
Yea there should be a bit riveted to the rear bulkhead. Tucks up under the capping. The rusty bit in my photo.
Instagram - @r22oyp
Roy
Post #885182 13th Feb 2021 9:53am
Mine was rivetted in too, until I drilled out the rivets and removed the thing. It stuck out too far.
Post #885186 13th Feb 2021 10:03am
Roy5695
Exactly what I did before the Line-x coating went in. No more pointy bit sticking out at the back for the dogs to hurt themselves on. Also beans anything I carry in the back can sit flush against the bulkhead. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #885187 13th Feb 2021 10:06am
astroarcadia
I have this spare and going free.......
Post #885206 13th Feb 2021 11:42am
astroarcadia
Yes the mounting plate is riveted in.
I drilled mine out as I converted my PU to a soft top and now mount spare on swing away arm.
Post #885207 13th Feb 2021 11:43am
Page 2 of 3 <123>
